1999 306 Gti6 stereo wiring.
Results 1 to 8 of 8
    Fellow Frogger! trihardthlete's Avatar
    Oct 2011
    434
    Default 1999 306 Gti6 stereo wiring.
    Have tried to hook up a new stereo and looked high and low for the color wiring diagram for my car, all the uk based ones have different color codes mentioned. Does anyone know off the top of there heads the power- speaker- etc color codes for a 306. Thanks for any help you can offer
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,330
    could you use one of these?
    Pioneer > 306 wiring harness
    2017 Renault Koleos auto
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by trihardthlete View Post
    Did you look in the Owners Manual? There should be a page in there (called "Fitting Stereo Equipment) that tells you which wires you need to look at.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Oct 2011
    434
    Looked through the manual. It only explains fuses and entering security code in the factory stereo. Going to try and download the Haynes page now.
    265
    If anyone here has a 306 with an Owners Manual, look up the colour coding. Its in there.
    Sep 2003
    North Parramatta
    3,997
    Sorry - I though they all had them.
    One thing on colour coding - it's not Peugeot's way. They are mainly interested in wire numbers or positions.
    As per the other thread that's remarkably similar to this one: Pioneer > 306 wiring harness if you pull enough wiring out, you'll find the "proper" ISO plugs for the stereo and with this page from an Owners Manual, it should be simple enough to work out.
    One 8 pin plug for all the speakers, and another 8 pin plug for the essential power bits.
    This is assuming someone else hasn't already put in an aftermarket stereo and buggered it up for you.
    Attached Files Attached Files
    Simon
    Oct 2011
    434
    Yeah unfortunately that is the dilemma. Previous owner has done a number in the last stereo and cut all the wires to short and left it a right mess. Will probably have a professional install it. Thanks for all the advice though. Has saved me more of a head ache
    Oct 2011
    434
    Anyone know the fuse number for the radio
