acceleration problems with my '93 405 mi16
Results 1 to 15 of 15
    Jan 2012
    8
    Default acceleration problems with my '93 405 mi16
    Hey all!
    i have had my mi16 for 5 years now and have had no real problems until recently.
    occasionally when i try to accelerate the engine revs through to 5000 but no power goes to the wheels. it is also lacking the pick up it had.
    i am hoping it isnt the clutch!
    spark plugs maybe?
    Jul 2011
    Gold Coast Australia
    48
    clutch
    1,376
    .....i try to accelerate the engine revs through to 5000 but no power goes to the wheels
    +1 - Clutch
    PDJ
    PDJ is offline
    Fellow Frogger! PDJ's Avatar
    Central Coast NSW
    204
    Spark Plugs?
    Clutch!
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    if there is not direct proportional match between RPM and SPEED (example if 1000 RPM = 6 km, then 2000 RPM must be 12 km/h, 3000 RPM 18 km... etc), then, clutch.
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    Lilydale, Melbourne
    2,095
    Yup, clutch.
    John W
    1974 Peugeot 504 TI
    - now on the road
    Dec 2010
    232
    Since you are saying "it lacks the pickup it had" I am assuming it still drives but feels under powered, is this right ?
    Being a 93 model, does that make it a phase 2 model, i.e. plastic inlet manifold with vacuum pods that probably dont function any more ?
    However if no power goes to the wheels at all, (rev counter climbs but car sits still, or barely moves) then as said above, it will be the clutch !
    Apr 2003
    385
    Default Cable....?
    405's have a clutch cable...if the cables sticking it could be a culprit..otherwise clutch assembly itself
    Jan 2012
    8
    Quote Originally Posted by blink View Post
    @ 3000 rpm no power goes to the wheels if i accelerate quickly but it will climb slowly slowly otherwise. the clutch functions normally. it lacks pick up off a standing start also
    Jan 2012
    8
    the car seems to not want to accelerate from 3000rpm, there is little power to the wheels if i try this, yes it is a mark 2!
    Jan 2012
    8
    can anyone recommend a good peugeot mechanic in the melbourne area?
    Melbourne Australia
    1,382
    Been covered many times before do a search on Melbourne mechanics .....
    Dec 2010
    232
    I suspect the clutch is not your problem, hard to tell without looking though ! check for vacuum leaks at the map sensor and check that the vacuum pods operate.
    Does the car take off with plenty of power once it hits about 5k Rpm ?
    And does it idle properly ?
    Jan 2012
    8
    yes and yes-are you available to have a look @ the problem?
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Alpine Affair in Ringwood... Best Pug repairer east of the city..
    for the clutch... get onto a flat road.. Put it in Fourth.. try and take off from a standing start... if you stall... your clutch is fine... if you can take off... your clutch is slipping..... seriously this works...
    also try: your battery terminals... mine lost power and it was a loose terminal. I cleaned it and tightened it, and no more loss of power. also look at your distributor (I think the phase two also has a distributor on the end of the cams)... clean inside it. finally check your spark plugs, check for water in the wells... you wash your motor and get water down in the plug wells, they short out the plugs and you temporarily loose a cylinder or three. Finally check air filter and ignition plugs... any of these things can quickly result in a loss of power. also these are easier to clean and examine than stuffing around with your fuel system.. and clutch. Besides, doing these is good maintenance... If it isn't this.. start looking fuel or Map sensor... or the evil clutch..
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
