504 Hard Starting
Results 1 to 15 of 15
    Fellow Frogger! Tom_95's Avatar
    Jul 2011
    Sunshine Coast, Queensland
    203
    Default 504 Hard Starting
    Hi there
    Finally got the 504 on the road after a horrible bout of missing. Turns out one of the Bakelite plug insulators needed replacing...
    Anywho, on a few occasions the car has been very hard to start when hot. I use the method of slightly depressing the throttle, as suggested in the manual. But this requires 3 or 4 goes at starting the engine before the thing fires. However, if I use NO throttle, it is just as hard to start...
    Any Suggestions?
    (The plugs, leads, dizzy cap, points and rotor button have been recently replaced)
    Thomas
    anywhere
    2,003
    I always seem to remember my 504 being hard to hot start. But when it got to a point where it wouldn't hot start at all, I tracked it to a coil. That was the early model where the coil was attached to the motor.
    Jul 2011
    203
    Quote Originally Posted by Russell Hall View Post
    How to you mean "Attached to the motor"? (Mine is a '75)
    19,211
    Quote Originally Posted by Tom_95 View Post
    The coil bolted to the alternator bracket between the water pump and the alternator.
    Isn't yours a (L)TI? These must have a special coil. A Bosch GT40 is nearest equivalent.
    Plug gap must be a bit wider than normal.
    Haven't we had a similar thread before or is it another car?
    If it's a carby car and auto especially electronic ignition off a later 504 or 505 is strongly recommended.
    Far North Queensland
    1,494
    From memory the coil was mounted on the alternator bracket.
    Paul
    A straight is merely the distance between two corners.
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Jul 2011
    203
    Yes, mine is a carby with a GT40 on the alternator bracket
    anywhere
    2,003
    The cars with the coil in that position had something of a reputation for overheating the coil.
    1000+ Posts Beano's Avatar
    3,142
    This does indicate it's an electrical prob. I agree about the coil...
    Jul 2011
    203
    Quote Originally Posted by Beano View Post
    Well, lucky for me we bought a parts car the other week. So once we've picked it up, I'll swap the coil and see what happens
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Try push starting. If it starts easily then it is an electrical problem .A new Ducellier competion coil and a reley on the positive wire to the coil [so the currint comes straight from the battery and not through 38 year old wiring] solved the problem for me
    Perth Western Australia
    2,694
    Tom,
    Check that the GT Bosch coil isn't meant for a ballast resistor type ignition. Very rare that 504's had this.
    Try a new ignition condenser.
    Jul 2011
    203
    Tom,
    Well, as I previously mentioned, I could try the coil on my parts car and see if I notice a difference...
    anywhere
    2,003
    I put the wrong coil on my 504 once and it cooked the points. But if the coil on the parts car looks genuine it should be ok.
    Jul 2011
    203
    Well, what kind of coil should it have? Because if the one on my car is wrong it can't be doing it any good; In saying that, the GT40 looks like it has been on their for quite some time...
    anywhere
    2,003
    The code is on the bottom and I forget what it should have - someone else will know. I've just accessed a green Ducellier 504 coil for my 203. But you can't put a 203 coil on a 504. The points overheating takes place within a short time, perhaps 100k's. I was just talking about that recently with a 504 owner who did the same thing.
