205 GTI strut top mounts
Results 1 to 25 of 37
    9,004
    Default 205 GTI strut top mounts
    Is there any place in Australia where I can buy the whole lot (bearings, cups and rubber bushes)? See picture here
    http://forum.205gtidrivers.com/index...owtopic=115214
    ACHTUNG ALLES LOOKENPEEPERS
    Jul 2003
    222
    One would assume EAI...?
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    7,483
    Peugeot. They sell a "strut rod fixing kit". You probably don't need the bearings. Just reco the old ones.
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    eai and when I checked last they were around the $180 per side mark.
    9,004
    Thank you, guys.
    How do you recondition a bearing?
    7,483
    The kit you need is #503521. It was $77 inc tax from Peugeot back in 2008. You'll need two. Doesn't include the bump stomp. For the bearings, soak in kero, clean etc., then regrease. They just get clogged up with dust etc.
    9,004
    Judging by the diagram linked above, I would guess if the strut has play at the top then it's the bearing that's gone, so I would think it can't be reused. Am I wrong?
    7,483
    Am I wrong?
    Yes..
    9,004
    Yes..
    Hmm. So why the wobble?
    9,261
    Won't be the bearing probably the rubber chopped out.
    7,483
    Rubber doughnut will be worn/perished etc.
    9,004
    Rubbers look good, but who knows. Both my GTI and the Si wreck have the same symptom.
    Ordered the kit(s) from EAI anyway. Are these OE?
    That guy who replaced the other guy at EAI is really annoying. He doesn't know anything. The other guy was really good. EAI, do you hear this?
    9,261
    Ordered the kit from EAI. Are these OE?
    Unlikely, would probably be SASIC.
    9,004
    Dang local Peugeot dealers not open yet.
    Any problem with SASIC?
    9,261
    Would a Peugeot dealer know what a 205 was?
    SASIC usually OK, if you want something heavy duty get the Group N rubbers from Bakers in the UK.
    7,483
    I prefer the kit from Peugeot as you get all the top parts of the housing new. I'll be keen to see if your EAI kit contains the same and at what price.
    9,004
    They said the kit contains the bearing, rubber and spring top (I guess it was the loser I mentioned above not actually recognising what is in fact the cup). 185$ a side plus shipping.
    Anyway, we'll see. I have had original Peugeot items supplied by EAI.
    Peugeot locally don't even recognise the car's VIN even though they sold it when new.
    7,483
    I'm sure you have a problem with the advice I give you. I've given you the good oil several times now and you continue to ignore it.
    9,004
    Parts arrived today, it's the original Peugeot kit, contains everything above the top spring seat (included too).
    Weird looking bearing. I thought it was going to be like a ball bearing or something similar (as the my old BMW or the Golfs have, that sort of thing), that's why I asked how do you recondition a bearing because something like that once the race and balls are stuffed, you can't do anything about it.
    Now for the bump stops and bellows.
    Not sure what is it exactly you are referring to about advice.
    1000+ Posts djvu205's Avatar
    1,402
    i bought the last geniune bump stop in aus yesterday, well thats what i was told, let me know if you find another one as i needed two. part # 503327 yellow 97mm $29.its yet to turn up in the post!
    9,261
    Quote Originally Posted by djvu205 View Post
    Places like Pedders need to be told where to buy bump stops, I've lost count of the struts I've pulled apart that have either none or ones that have disintegrated.
    Got a set of fairly new LIPs out of a GTi the other day, stuffed and leaking oil due to virtually non existant bump stops.
    The SASIC stops survive rallying fine so no problems in their use.
    Graham
    1,402
    Default bump stops
    yes tried pedders they tried to sell me a universal one that wouldnt even go on the strut shaft. then he tried to sell me one half the height and dia. after that he looked iot up on computer and quoted me $200+ for a sasic kit which did both sides and included 2 x stops and 2 x boots. not sure if you got zip ties with that?
    9,004
    Are the Si bump stops the same as the GTI?
    My SI wreck seems to have nice bump stops and bellows even though I would say they are aftermarket.
    7,483
    [QUOTE=schlitzaugen;1021587]Are the Si bup stops the same as the GTI?
    No, different length.
    9,004
    [QUOTE=PeterT;1021594]
    Bummer.
    There isn't much one can swap across from an Si to a GTI, is there?!
    How does this bearing I have just bought work? What is the friction reducing material in there? I am tempted to destroy one of the old ones to see.
    Is there any mod warranted/possible to replace this bearing with a real bearing as in the cars mentioned above? I don't understand this bearing therefore I don't trust it (even though common sense says otherwise). I'll try when I have everything off a top strut bearing off my beemer just for kicks.
