205 Odometer woes
Results 1 to 8 of 8
    Feb 2011
    29
    Default 205 Odometer woes
    Gday,
    After acting up for a few weeks it appears that my odometer has finally stopped ticking over. I know a few people will probably chime in that this is one problem you don't wanna fix but for the sake of service intervals I want to get it spinning once again. The trip meter is moody but generally works as long as it isn't reset whilst the engine is running.
    I took the instrument binnacle out once before but couldn't figure out how to get at the inner workings of the odometer. Does anyone have any experience with this? I searched the www and the foum and couldn't find much on this topic (not even on GTI Drivers).
    Any help or advice is much appreciated.
    BTW the car is a series 3 205 GTI.
    1000+ Posts djvu205's Avatar
    1,402
    maybe just a speedo cable? or has the needle dropped off?
    Feb 2011
    29
    The needles are fine. The mileage on the odometer doesn't turn over.
    I.e. I know how fast I'm going but not how far.
    8,997
    the inner workings can be accessed but it's a pig of a job.
    You need to take the cluster out, take all the bulbs out, peel off the foils carefully after you took all the little brass nuts out and the back plastic (white) which clips into the glass (transparent plastic). You will find then that the dials are in four sections, one at left with the oil pressure gauge and fuel gauge, one in the middle with the speedo, one with the tacho, and one with the oil temperature and the coolant temperature. You can replace just the one which is faulty if you have a spare, or try to fix it once you pull it out of the assembly.
    Good luck.
    ACHTUNG ALLES LOOKENPEEPERS
    1,402
    Quote Originally Posted by RalphWiggum View Post
    ah yes i here you now, i just didnt read the original post properly
    Jul 2005
    328
    I had the trip meter fail in my old Si, and to repair it I had to remove the odometer mechanism.
    It was fairly straight forward from what I can remember, but to remove the mechanism I had to take off the needle from the shaft. I used a piece of polypropylene (from a document wallet or similar) with a slit in it, that I could slip under the needle and pull it directly upwards from both sides. Remember to mark the correct orientation of the needle somehow. Then undo the two screws either side of the needle.
    I don't remember a way to remove each instrument set without removing needles, but this may either be model differences.
    Also, don't turn the instrument panel, or the speedo, upside down. I have heard that there is some dampening fluid or somesuch that might leak - dunno if it's true but why risk it?
    The problem with the trip meter was a broken bit of plastic on the end of the reset button, and I wouldn't be surprised if broken plastic is the culprit here, so be careful not to loose any tiny bits floating around inside. Fix with 'super glue' (clean very well).
    Some pictures:
    Hope this helps.
    '96 Peugeot 405 SRDT Station Wagon
    '71 Peugeot 504 GL - gone
    '91 Peugeot 205si - gone
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    Default pm sent
    pm sent: Ive a couple of spares if anybody wants one
    Feb 2011
    29
    Thanks so much for all of those replies. I'll print out those instructions, give the thing a shake and let you all know how I go.
