Full lock squeal...?
Results 1 to 9 of 9
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    Default Full lock squeal...?
    Hey,
    The 406 has started making a "screeching" noise when the car is on full lock - plenty of PS fluid with a new belt - so the pump isn't being starved and the steering feel is consistant...
    Please don't tell me that it's a crankshaft pulley - I'll be mighty pissed off as I had the cambelt done 2 weeks ago!
    Annoyed,
    Stalled.
    2005 Renault Clio 182 Cup
    Near Mullumbimby, NSW
    347
    Maybe the new belt just needs tightening a touch?
    Goonengerry 505
    12,266
    relief valve in the pump sounds like it's on it's way out
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    8,426
    Quote Originally Posted by STALLED View Post
    Hey,
    Great, now you know that you have turned the wheel too far and can back it off a bit.
    Jo
    265
    It's probably the harmonic balancer. Get some white out and draw a line on it. Have it screech then check if the line is offset when its off.
    Mar 2011
    Kendenup WA
    124
    Time for a new belt.
    There is always some slight slippage even when adjusted correctly. Eventually the surfaces of the belt will glaze and to eliminate the noise it is common practice to overtighten - to the detriment of bearings.
    Oct 2003
    2,865
    Quote Originally Posted by Pavel Moore View Post
    The Belt is 2 weeks old :p
    9,261
    Almost sure to be the problem then, the belt will stretch a bit when it is new.
    Oct 2003
    2,865
    A/C Pulley doesn't like the belt - problem solved!
    Cheers - thanks for the help!
