mi16 engine oil flush
    1000+ Posts Isis's Avatar
    1,100
    Default mi16 engine oil flush
    I am moving from a full syn 10w60 to a 5w40 full syn oil. I dont suspect that the engine is particularly fouled up but it is blowing a bit of smoke on cold start up on the 10w 60. I dont drive the car much.
    So, I have already drained the old 10w 60 and put in a fresh batch of the same 10w 60 for a flush out. I now plan to run that for perhaps 20 mins at low revs and drain that out for a long time, then put in the new filter and new 5w 40.
    Any pointers with this flush out - do people for/advise against any additives to try and get an extra clean?
    thanks
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Melbourne Australia
    1,382
    Personally I think additives are a waste of money on a well serviced car. I would do exactly as you are suggesting ie. engine nice and hot, drain over a lengthy time and I would take off oil filler cap and pull out dipstick to assist draining.
    Interested to see you going to a thinner oil which is generally the opposite of what most people do to reduce smokey engines. Have you determined a cause of smoke eg. valve stem seals, etc or had someone follow you to see if it is smoking all the time or performed a compression test ?
    Happy to assist if you need a hand cheers
    8,284
    Quote Originally Posted by Andrew Ch View Post
    I was wondering about that too.
    Is a typo, or is there some merit in going thinner???
    Jo
    1,100
    thanks guys. The previous owner said he had no smoke trouble on this thinner oil apparently, after I asked him the same question. I can only say that the car did not blow smoke before I switched from 5w40 to 10w60 (when I first got the car). I am thinking that the 10w60 has degraded quite quickly under the duress and heat of the turbo. My engine was rebuilt not that long ago - 5-6 years and not done much work or K's since then really.
    If the swap does not work I will get a few tests done.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
