The Silence of the Blower Motor.
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Default The Silence of the Blower Motor.
    The wife's N5 306 has a bugger of a problem. The air con fan isn't working.
    There appears to be nothing wrong, but the fan just wont go. The fuse is OK.
    Anyone know where I should look first to check for faults.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    Dec 2010
    232
    I would stick my head in the passenger side foot well, remove the fan and test for voltage at the plug, then go from there. If there is voltage, then the fan will need replacing or maybe fixing if possible.
    Dec 2004
    Geelong
    214
    Yeah... The motor just drops out does it not?
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    Dec 2010
    232
    Pretty much, has about 4 screws holding it in place if i remember well.
    Sep 2003
    North Parramatta
    3,997
    Remove it, give the bearing a bit of a soak in something (WD40 if you must) and reinstall.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Dec 2010
    Mirboo North
    158
    Just a thought - If it were mine I'd be testing it with a known good 12v supply before spending the time re-installing one that might not be right electrically. If it's like the 405 blower, there might be a blown transistor or two, darlington power transistors in a TO-3 case if I recall correctly....I got the details somewhere.
    Cheerio,
    Geoff (in Mirboo North)
    1994 405 SRDT white - (free to a good home, unreg. & needs injector pump re-fitting)
    1997 Toyota Hilux Surf
    2007 Citroen C5 Hdi Wagon
    2003 Merc Vito 112Cdi
    non-sequitur - 1951 Hudson Pacemaker brush-painted matt black!
