Aircon repair - Sydney Northshore side or inner west
Results 1 to 19 of 19
    Jan 2006
    128
    Default Aircon repair - Sydney Northshore side or inner west
    My regular aircon guy seems to have disappeared so need someone to fix a leaks and do a regas. Any recommendations for me ?
    Its going to get hot soon !
    Many thanks
    P306
    8,433
    Highly recommend narrabeen auto electrics.
    http://www.yellowpages.com.au/nsw/wa...8-listing.html
    Jo
    Sydney Australia
    55
    Boony,
    Try North Shore Auto Electrical ay 2/79A Victoria Ave Chatswood. 9417 7211. These guys do the electrical work for PQ Automotive. They have done some work on my 407 and they're good.
    Also, there is a guy called Enrico that had a business called Amps Auto Electrical - he used to be at Leichhardt, but was working a couple of years ago from Big-T Automorive in Formosa St Drummoyne. Not sure if he's still going though. He did the aircon on my Alfas a couple of times, also did the aircon on my wife's old Mi16. He's good too if he's still around.
    Hope this helps.
    John
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,446
    Default Recommended air/con repairer
    Graig - 0417703700 - He travels to your place.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    7,488
    2nd vote for Craig - AC Mobile Air. He's also pug savvy.
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,869
    Quote Originally Posted by John Wiltshire View Post
    Boony,
    +1 - They did work on my 406 and so far so good!
    2005 Renault Clio 182 Cup
    Jan 2006
    128
    Boony,
    John
    Thanks. Thats my aircon guy but I tried calling last week and on Monday and there is no answer. I also left a message with no reply.
    Assumed that they had closed...
    Sydney Australia
    55
    No - they're still there 'cause my 407's going there tomorrow!
    If you can get hold of them, give Maurice at PQ a call - he uses them a lot.
    John
    NSW
    4,918
    Is he Citroen savvy...?
    Oct 2003
    2,869
    Quote Originally Posted by danielsydney View Post
    *facepalm*....
    Considering your C3, is a Peugeot in drag - the answer would be yes.
    Jan 2006
    128
    John
    Called Maurice (he does my car also) and was told NorthShore Electrical has closed down....
    dvr
    dvr is offline
    707
    Find somebody who'll repair and regas with hydrocarbon ie butane-propane. Best substitute as it's more efficient and operates at lower pressures so less likely to leak or cause you problems in future.
    If you can't find any ask Bursons at Blacktown for one of their Hychill customers.
    Far North Queensland
    1,494
    Default Testing Air-con Compressors
    Local aircon shop bench tested compressor from 205 Si. All he could tell me was that it was pumping.
    Do any of the larger aircon service places have facilities to do a full test on compressors?
    Don't want to fit and gas it only to find out that the seal is leaking.
    Recon price quoted wasn't much short of price of new compressor.
    Getting to the stage where resurecting the aircon will cost more than I paid for the car itself.
    Paul
    "A straight is merely the distance between two corners."
    Jan 2006
    128
    [QUOTE=504-504-504;1000794]Recon price quoted wasn't much short of price of new compressor. Getting to the stage where resurecting the aircon will cost more than I paid for the car itself.
    QUOTE]
    Got mine reconditioned two years ago and its true its not much cheaper than new. Can't remember exact prices but possibly $800 versus $1200 new all up. At that price my compressor IS worth more than the car.
    240,000km's and still going great. Pity about the exterior now
    Does hydrocarbon also produce slightly cooler air than the regular stuff ? I always thought there was only one choice....
    dvr
    dvr is offline
    707
    [QUOTE=boony;1000807]
    Quote Originally Posted by 504-504-504 View Post
    ...Does hydrocarbon also produce slightly cooler air than the regular stuff ? I always thought there was only one choice....
    It's much more efficient at carrying away the heat. So much so that only about 30% of the specified charge weight needs to be put in. Less pressure and bigger molecules in the system too, so fewer leaks and lower engine loads. Industries such as mining trucks and taxis where they aim for minimum down time and costs, use it.
    OKA, who manufacture trucks and other off road vehicles in WA, use it as OEM. They've done so "QUIETLY" for over four years to avoid the soothsayers and vested interests in HFC's. Those parties claim it's a bomb waiting to go boom. Same for a lot of a/c shops and techies who envisage smaller profits.
    Interestingly, some countries such as Germany have laws that only hydrocarbons can be used in refridgeration so all commercial and home fridges and a/c have it.
    It isn't a greenhouse gas like the others either. Do a google for "Hychill" if you like to research it further.
    Apr 2005
    866
    Hmm I need aircond work done as well. Problem for me (at least I think it is a problem) is that mine hasn't been touched in the last 17 years, and I think it still has CFC gas in it (what's left of it anyway). I vaugely recall that when changing gas to non CFC's all seals have to be replaced.
    I guess any of the guys mentioned in this thread should know the drill. If anyone knows I need to do anything special (that these guys won't know about) Please speak up!!
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Apr 2005
    866
    Default Hychill in sydney for anyone interested
    I decided to get the car re gassed with hychill minus 30 (direct drop in replacement for R12) and only uses about 30% of the weight). JM auto air in campsie did it for me today. It's only 22deg today so not a great test, but even at idle the air is super cold. I don't think it has been that cold at idle for as long as I can remember (at least 10 years) if ever! It hasn't been that cold at all (even cruising at 110 on the free-way) for a good four or five years I suspect.
    The guy there was very helpful. He Got me a new drier as well. Nice and simple, no need for changing seals or anything. He said the compressor was working well. The other plus is that it seems to have less of an impact on acceleration than what the old r12 did (when it was still working).
    http://www.jmautoair.com.au/
    Tony.
    306 S16 1995 black
    Jan 2006
    128
    I just got the re-gas done in Artarmon. Just regular stuff. Let us know how the Hychill works on the hot days.
    Apr 2005
    866
    will do, it has been unseasonably cold of late!
    Tony.
    306 S16 1995 black
