Removing 504 distributor
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    798
    Default Removing 504 distributor
    Hi,
    I'm going to be putting my engine together soon with the electronic ignition. So, I need to blank off where the distributor was, as I'll be using a 36-1 wheel. Question is, does something need to be in place to put pressure on the distributor/oil pump drive shaft to stop it jumping up? I haven't looked closely at it, but depending on the way the gears are cut in relation to the rotation of the motor, it may or may not need something there... or could I just get away with a blanking plate to keep dust out?
    8,433
    Quote Originally Posted by callipygous View Post
    Hi,
    IS that the same block as a fuego/r21/r25??? (sorry i dont know pugs)
    If so, there is a plate that bolts on which has an o-ring oil seal and a surface to contain the shaft as you mentioned.
    There is a prety cast alloy plate and an ugly pressed steel version.
    If it is the same and you want a plate, I've got a few ugly steel ones to spare.
    Jo
    Jan 2005
    Ferntree Gully, Melbourne, Victoria
    210
    Hi Mark
    All i did was just cut the top of the original distributor and bolted it in. In the end, i used it as a cam trigger for the ecu so that i could run sequential ignition and injection.
    You should also be able to use some Teflon rod in its place.
    mike
    1972 504 Ti
    Jan 2006
    Toowoomba
    798
    Jo
    Thanks, but it's different.
    Jan 2006
    Toowoomba
    798
    Quote Originally Posted by Mike L View Post
    Hi Mark
    mike
    So you do need something to hold it in place then?
