404 clutch bleeding
Results 1 to 9 of 9
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    Default 404 clutch bleeding
    hi just wondering if anyone has a great tip on bleeding a 404 clutch
    i have bleed it by using the brake caliper with hose to clutch slave and then pumped the brakes etc, all air seams to be out of the transperant hose but still a little at the master cylinder, have jiggled valve in master cylinder.
    i have got the clutch to work but you need to push it in with your tippy toes to get it to free so there must still be some air in it
    clutch master and slave are brand new also new clutch throw out bearing and preasure plate
    Member 504pug's Avatar
    Jun 2011
    brisbane qld
    41
    Ive always bled my brakes not by pumping but by opening the bleed nipple and waiting for gravity to do it........takes quite a while but it seems to get every last little bit of air out and you don't need an assistant
    don't know if you could do the same with the clutch
    just a thought
    9,283
    Quote Originally Posted by Balki View Post
    You probably need to fit a spacer between the rod and the piston. 404 clutches are quite marginal, they are both lighter than the 504 and have less pedal travel, so the diaphragm movement is a fair bit less.
    To bleed push down the valve while lifting the lever with your hand, no need to go inside to push the pedal.
    Graham
    Sheffield/Tasmania
    631
    Default clutch
    thanks graham will give it a try i have left the bleed nipple open all night so will try again tonight
    when you say a spacer between the rod do you mean the slave or master
    Perth Western Australia
    2,694
    Balki,
    Is the bleed nipple on the slave cyl pointing upwards? Have found this necessary to completely bleed the slave.
    You seem to have everything else covered. "Tickling" the clutch m/cyl valve has always worked for me.
    Graham's spacer may do the trick. Haven't heard of that one before.
    19,211
    The brass nipple off a spark plug HT end between the master push rod and master piston is perfect length.
    Assemble the whole lot off the car, orient the master and slave as suitable for easiest bleeding and bleed.
    Then dangle the the slave, off the nylon line in front of the firewall. Catch from underneath and slide in place and fit the snap ring.
    Then you need to fit the support the clip which is screwed the wiper motor bracket after that.
    9,283
    Make sure there is still some free play in the pedal, you may have to trim the spacer.
    Sep 2004
    Tamworth UK
    624
    My issue has been freeing the slave from the bellhousing, any tips?
    19,211
    Quote Originally Posted by kiwia110 View Post
    • Spray with Innox.
    • Remove the the snap ring and nylon line.
    • Grab the biggest meanest shifter and apply to flat faces of the slave cylinder
    • Rock the shifter backwards and forwards until the cylinder moves a tad
    • Apply more Innox , and keep rocking backwards and forwards
    • Once it rotates freely change, to vice grips and twist backwards and forward and pull at the same time.
    Make sure the car is securely on stands. Use your foot bracing off the car body on the shifter initially.
    Use some lithium grease when you reassemble.
