405 series 1 dicky a/con
    158
    Default 405 series 1 dicky a/con
    I have a series 1 405MI16 . The air conditioning does not always actuate . The switch will light but faintly but when the compressor locks in it glows at full brightness and the air works properly . I understand there is a small circuit board that does the switching , could this be my problem and where is it to check it out . how would I get it out .
    Any help appreciated to calm an annoyed wife
    tweed heads
    1,503
    Default pressure switch
    theres also this switch ,which opens circuit when gas pressure is low contacts could be dicky it will be somewhere under the bonnet in a gas line ,check the contacts were it plugs in .PUGS I HAVE A 405 HERE BUT ITS NOT HERE NOW ,IL CHECK LATER
    Northern NSW
    1,079
    Might be on the verge of needing a regas. If you take it to the aircon bloke he'll soon work out the problem. I've found they are usually pretty good and not too spensive.
    158
    Air is freezing when operating so I think it has plenty of gas , will have it checked though , but bad contacts will be well worth checking out .
    Thanks for your help guys
    pmc
    pmc is offline
    20
    Default maybe the thermostat
    Hi had a problem with the clutch not engaging all the time on my 205 and it turned out to be a faulty electronic thermostat which was replaced by a mechanical one now ok...
    good luck but point auto electrician there if the gas is ok and an intermittent fault
