Hi everyone,
it's been a while since I've posted on the forum, and I realised that I should probably show you the work I've been doing on my 504 lately.
A few months ago I decided I would get louvres put into the bonnet to allow the heat from the engine to escape more easily. This of course meant that I'd need to respray the bonnet. The bonnet came up really well, so I decided I'd paint the whole car.
So I've now finished spraying the car, except for the two front guards and the nose, which I'll get onto next year. At the moment I haven't polished the doors, but they still look pretty good. I'm really happy with the crease lines down the rear quarter panels and the doors - the passenger side was pretty knocked about before I pushed dents out and fixed them up.
There was a little bit of rust around the bottom corners of the rear windscreen. This has been cut out and welded up now. I made sure to adjust where the drain pipes sit so that water wouldn't sit in that area again.
Eventually I'll pull the engine out and do the engine bay, but for now it's too much work pulling all that plumbing apart. The louvres work really well, you can see the heat dissipating from the bonnet when you idle!
Andrew
