205 issues when warm/hot
Results 1 to 24 of 24
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    Default 205 issues when warm/hot
    Hi all, thx for any advice in advance.
    205gti s1.5 - jetronic - recently rebuilt warm 8v
    when cold will pull like a train to redline
    when warm stutters 2.5k rpm upwards, wont pull past 3.5krpm
    when hot 3k rpm especially coming back on throttle if you stomp it might rip your neck off / stuff your driveshaft with stuttering on / off power
    after a long run if you start it within 30 minutes it will run on 2 cylinders for a while
    Initially it had been blowing blue smoke at startup - good guess that the AFM was stuffed and replaced it. That helped it idle and could set the dizzy where it needed to be but it still has heat issue.
    Replaced the coil last weekend, no effect, perhaps made it worse
    I'm thinking maybe the SAD is playing up, but even so I'm guessing it wont cure the heat issue completely, especially the bit where you let it sit and it will nearly not run.
    Bring on any advice, kudos given for things that can be done cheaply
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    blue smoke? thats oil mate..
    before you throw more parts at it, have a think about it.
    why would it be the coil, usually they do or dont work (in most applications). youve replaced it so its not it.
    why would it be the afm, mine was shot on my parts car but it ran like shit and stalled. you replaced this and its not it. (unless its the wiring thats bad)
    why the SAD, that to introduce extra air on cold startup, and you say its fine cold
    so we've gathered its temperature related. Start doing a pressure test on the cooling system and check for leaks. may as well do a compression test while your waiting for the pressure tester to sit for a while. never hurt anyone but its a million to one chance its related. then, are the fans cutting in and out as they should when its hot? take note of the speed & number of fans running. out of coolant? stupid suggestion but its possible. Is the top radiator hose getting hot followed shortly after the bottom hose? heater inside the car blowing hot air? if not, radiator/thermostat/heater core need rectifying. That working? maybe the fuel/timing is wrong, and its either from (can the dizzy on the 1.9 8v be adjusted? ive got an mi16 i dont know) incorrectly adjusted timing or the engine ecu is not receiving the correct values to adjust its timing parameters accordingly....... ->coolant temp sensor<- i'd personally replace this first, obviously after completing a raft of free checks im sure you can do at home then i'd start looking at the ignition system
    Hornsby, NSW
    1,012
    this is assuming that the correct oil/coolant/spark plugs are being used and something obvious hasnt been overlooked. I have an old-new stock SAD lying around at home if you REALLY want a new one
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    Have you tired the ignition amplifier??
    Hornsby, NSW
    1,012
    Why the ignition amp module? expensive to replace unless your sure it's at fault. I'm not saying rule it out but saying do those mechanical checks you can do for free. The guy I bought a 205 gti off had spent hundreds of dollars trying to get it to run right. Replaced pretty much the entire ignition system to no avail. It stalled when taking off and bogged down. A load related system is failing. Ignition wouldn't cause this. Air flow meter straight up, swapped with a spare worked fine.
    Like i have to do at work, an idea needs to be 'sold' to a customer. If you said ignition module needs replacing, they may very well ask why. 'ummmm' doesn't work too well. I quoted a stop light switch and solenoids for someone with a 207 with a clunking auto gearbox. Didn't fix the problem, but sold to the customer how a faulty stop switch (int. Open circuit logged) can confuse the shift pattern, failing solenoids can cause harsh changes and then sold a gearbox reco because of an internal leak, and 'sold' the fact that we can't tell it's the gearbox because solenoids show the same symptoms (which is true, lower valve pressure to the reference value given) And they are cheaper and are common on al4 gearboxes.
    These things just need some logical thought, or you'll be that stereotypical person who spends alot of money on their French car and constantly reminded to by jap crap.
    8,434
    Quote Originally Posted by spar View Post
    I dont know a thing about jetronic so this may be totally irrelevent.
    Does the ECU use a coolant sensor to set timing and/or fuel?
    If so, check that it is operating correctly.
    On modern EFI, coolant temp is one of the primary sensors the ecu relies on, so a guess would suggest you check the function of yours if there is a relationship with the tune.
    Jo
    8,434
    Quote Originally Posted by Capago View Post
    I quoted a stop light switch and solenoids for someone with a 207 with a clunking auto gearbox. Didn't fix the problem, but sold to the customer .........
    Sold me on DIY.
    Jo
    sunny coast
    263
    it was fuel smoking at startup - ECU giving full fuel load not knowing what to do - and the replacement AFM fixed that.
    this also cured its problem of having to advance the ignition heaps to get it to idle.
    AFAIK one of the common things a coil will do when breaking down internally is to fail when getting hot - especially the bit about when it loses 2 to 3 cylinders if you let it sit when hot.
    (this is also true of wiring, condensors and other electrical bits and bobs)
    well i aint going to compare my >20 year old 350,000km recycling project i bought for nothing against the last brand new japanese motorcycle capable of never even misfiring for 5 years - lol.
    I honestly appreciate advice, but c'mon, you dont have to assume everyone is a complete turnip and straight off the bat be condescending, especially with your advice having at least 1 wrong thing in it !
    sunny coast
    263
    Jo
    Ok this sounds plausable - my experience is old school carby and points stuff - and this can be checked for free
    sunny coast
    263
    Quote Originally Posted by gezza View Post
    I'll have a look today and try to find how to test this.
    1,376
    I'm going with ignition amp as well. Had a turbo laser with the same problem. Every time it got warm / hot, it would break down. The ignition module was the cause albeit a different system. If you can get it down the coast, I have a spare you can try.
    Moo
    sunny coast
    263
    Quote Originally Posted by PugMonkey View Post
    Moo
    Cheers Monkey but its a 2 hour drive from where we are... would have liked to see your beasty tho.
    Off to google if its possible to check if its working.
    Shane
    Hornsby, NSW
    1,012
    Sold me on DIY.
    Jo
    Yea mate did the work myself, with full printouts from Peugeot Planet 2000 diagnostics, following infoflashes from Peugeot and checking my findings with our senior factory trained techs. So yeah.. Not a bodgy DIY job mate. I'm a 2nd year apprentice pug mechanic.
    what I was getting at was why just say to someone replace x y and z without any sort of explanation. If it was me with this car I'd want to know why I'm replacing something before i even look at my wallet.
    and look "SPAR" got the info about the coils wrong, only in my short 2 years ive dealt with EFI ignition modules and coilpacks, which give open circuits if anything if they fail, never worked on anything pre-99 at work. but as you said you replaced your coil so idk. carbs isnt my thing. and you "sold" the idea to me that it could be the coil or its wiring, you explained it, i understood it, and the idea was "sold" and accepted
    Look, if im wrong, feel free to correct me or whatever, i just provided a logical step-by-step test/s in case you didnt know. Just trying to share my 2 cents
    sunny coast
    263
    When ever I have had problems with ignition amps before, it has always been because the paste has dried out. New tube of heatsink compound from somewhere like Maplins for a few quid. And it's all sorted.
    http://forum.205gtidrivers.com/index...howtopic=89674
    now this sounds plausible and is easy to try, i have some arctic silver cpu thermal paste, might be good enough.
    its under the coil, else i was thinking of screwing a little gnu fan onto it also, i have them lying around.
    +1 for a free thing to try
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    TDC sensor can cause similar symptoms when it starts to fail.
    Not shore if the ECU's in the 205's will show the engine fault light if it gets a bad reading from this sensor. It may not have any way to know.
    Sometimes pulling them out and cleaning them can improve the problem temporarily. Try this and see how you go.
    sunny coast
    263
    well thanks for that but to be honest they seem only logical steps only for a different set of problems than i have.
    Hornsby, NSW
    1,012
    to be fair it is a temperature related electrical fault, and its either a sensor or as you said, the ignition system. im not standing in front of your car, you are, and you know alot more about the situation than i do.
    sunny coast
    263
    i dont know jack but i'm just trying to work through it, i can guarantee it isnt just 1 fault tho... lol
    and i'm happy out of 2 fixes 1 was right
    if the ignition amp requires heat dissipation and had paste from the factory then you can place a fair bet after 20 years in an engine bay it isnt going to be in great shape. that could explain the long term getting hot issue, wont solve the immediate *someone cut the ignition* problem which could be as simple as a brittle wire - somewhere.
    Bunbury
    2,191
    After owning 13, 205 gti's and having to replace the ignition amp on 3 of them my money is on that.
    Tech books only give you so much info.
    Real world experience of owning and driving these cars over the last 18 years helps better than any book, although books do help
    I am saying ignition amp with presuming it has had various new parts already with service's Ie dizzy cap, leads, rotor arm plugs etc
    sunny coast
    263
    just wow, $3500- of 8v engine install and one of the ignition leads had been routed under the air filter so it sat on the exhaust manifold
    now i'm a bit embarrassed that i didnt notice this and even replace the AFM months ago but...
    I was looking for odd things cause that very respected 205 mechanic had it for 2 x 1 month spats after the engine install and basically told me the harness was stuffed and i need to rewire with an aftermarket ecu.
    well that may be the case in the long run as i havent gotten it sorted yet but... it certainly hasnt gotten the basic things done properly and thats where i am going back to.
    i am going to do everything on my car now (well apart from suspension) - pfft expert my ass
    sunny coast
    263
    btw - i reckon i can rule out the ignition amp overheating (assuming i'm getting the right part, in between the coil and the bracket), i dropped a couple of ice cubes on it when it was hot and it made zero difference
    Bunbury
    2,191
    Lol always the simple things!!!
    Yeah I always service my own cars I know its done right then
    Far North Queensland
    1,494
    Same here. I can make the same mistakes the "experts" do and a damn site cheaper.
    Paul
    "A straight is merely the distance between two corners"
    Bunbury
    2,191
    Exactly!!
