'Nother paint code question
    Fellow Frogger! cam740's Avatar
    Apr 2005
    Southern Beaches SA
    868
    Default 'Nother paint code question
    Hi all,
    Trying to locate a paint code for my 89 Mi16, red in colour, but am buggered if i can find it under the bonnet.. Any suggestions of where to look or what the code/name would be?
    Fellow Frogger! jurgen_s's Avatar
    Belgium
    707
    isn't there a small metal identification plate? Besides the VIN, it should also contain the paint number. With peugeots from that era it should be a four letter/number combination.
    www.peugeotforum.be
    Belgium Peugeot Club
    Sep 2003
    North Parramatta
    3,997
    Well they certainly don't make it easy.
    It's painted in faded white paint on the passenger (or left) side strut tower, next to the power steering fluid reservoir as in this attachment.
    In the attachment, the code is P3JZ, which is Regency Red.
    PeugeotLogic, of course, have the relevant paint codes for most Pugs.
    Attached Thumbnails Attached Thumbnails 'Nother paint code question-405paintcode.jpg
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Apr 2005
    Southern Beaches SA
    868
    thanks for that guys, its helped to be able to narrow down the search!!
    Bad part is there is NOTHING on that strut tower
    anyone game to have a guess from the attached pic?
    Attached Thumbnails Attached Thumbnails 'Nother paint code question-img_5473.jpg
    Member 96306N3's Avatar
    Sydney,Australia
    90
    P3KG Scarlet red ???
    Belgium
    707
    what I can find on the dutch 405 forum:
    normal paint (without varnish):
    Cabernet POJR
    Carlet P3KG
    Cherry/Lemans P3KB
    Regency P3JZ
    Vallelunga P0KB
    metallic:
    Pagoda M0JP
    Pearl:
    Alhambra M4JF
    Alhambra M1JF
    Alhambra M0JF
    Alhambra EJF
    Diablo M4KQ
    Morello M0KW
    Vulcan M0KZ
    So finding any of this codes somewhere on your car should give you a good indication. However, if the color is non varnish beware of the effects of UV degradation of the paint. You therefore need to have a color sample pallet where you can verify the color of your car with the color samples available. That of course can only be done if all contamination and oxidation on the paint is removed. That can only be done by polishing the paint.
    www.peugeotforum.be
