306 temperature
Results 1 to 7 of 7
Thread: 306 temperature
    Sep 2011
    Perth
    15
    Default 306 temperature
    Hi guys,
    i have just bought a a 1994 306 XT with 185k on the clock.
    The thermostat hovers around the 90-95c mark. Is this high?
    I am quite paranoid after blowing a head gasket twice before.
    Any advice on prevention would be appreciated.
    perth306
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    628
    Usually pugs run just under 90c
    When does your fan engage ?
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Member jason's Avatar
    Jan 2011
    64
    Yeah man, check that your fans are kicking in just before 100.
    1000+ Posts stuartb's Avatar
    Apr 2002
    somewhere over the rainbow
    1,445
    Check that BOTH he fans are working..if its only 1 fan its not kicking in til too late...read waht Ive said about fixing this as its a common fault and 306 head gaskets are all too common and quite often a result of this stupid design
    Sep 2011
    Perth
    15
    Thanks a lot guys.
    The fan kicks in at 90c. Ill try to determine if it is one or 2 fans
    Apr 2002
    1,445
    Ipswich, Queensland.
    1,921
    I fitted a diesel thermostat to my 306,405 SRI S1 and 2 and S2 Mi16. I think 82 degrees instead of the 88? degree standard one. I also didn't like mostly running around the 90 degree mark. No change in the running or fuel economy that I could tell.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
