205 GTi in Classic Targa Adelaide 2011
Results 1 to 25 of 25
    Tadpole RallyPug's Avatar
    Mar 2005
    Bridgewater
    19
    Icon7 205 GTi in Classic Targa Adelaide 2011
    Hi people
    Here is some bumpercam from Classic Targa Adelaide 2011, with pure engine sounds.
    Targa Stage 23 - Norton Summit
    Enjoy
    http://www.youtube.com/watch?v=wLsvtBFSDwg
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,378
    Nice one! Thanks for the post. Is it your car?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Mar 2005
    Bridgewater
    19
    Yes my car, it used to be a dirt rally car, until I rolled it.
    It has now been re-shelled and converted into a tarmac car
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    Quote Originally Posted by RallyPug View Post
    nice, looked like fun
    still an 8v by the tappety sound ?
    considering the near goat track that was being run on i reckon the dirt suspension would have been quite handy lol, i'm thinking my car would bounce around like a cork !
    Mar 2005
    Bridgewater
    19
    Yes still an 8V
    In order to comply with the CAMS tarmac competition regs, its needs to remain an 8V.
    It's far from stock though
    Attached Thumbnails Attached Thumbnails 205 GTi in Classic Targa Adelaide 2011-_mg_0299.jpg   205 GTi in Classic Targa Adelaide 2011-_mg_1938.jpg   205 GTi in Classic Targa Adelaide 2011-_mg_9817.jpg   205 GTi in Classic Targa Adelaide 2011-interior.jpg
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    Fantastic stuff. Good to see some more footage of them getting out.
    sunny coast
    263
    Yes still an 8V
    nice 205 - i've no problems with 8v's, i like mine when it runs properly and it looks like you were going fast enough
    seemed a long first, i gather you have custom ratios? or is the quaife longer than stock?
    1000+ Posts Isis's Avatar
    1,100
    I bet the 205 set a good time on that road. I for one would be interested in hearing about your suspension,brakes, tyres and how much time it took to reshell!
    Well done
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Mar 2005
    Bridgewater
    19
    Gearbox is a standard BE1, LSD is a Tran-X
    Suspension is Koni adjustable with harder springs in the front.
    Brakes are standard early Series 1 with drums at the back, Ferodo pads
    Tyres are 15' Yokohama A050's
    It took 4 years to rebuild the car. Completed just 15 mins before documentation.
    50mm DMS Gravel suspension (Front & Rear) will be for sale soon as is surplus to requirements
    1,100
    Geez, my brakes must be overkill then.
    Did you have to get a whole new cage as well or could you cut it from the old car? Do you think a full cage is critical to stiffness and making the suspension work?
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Mar 2005
    Bridgewater
    19
    GTi 6 front caliper and 205 rear disc conversion is planned. (ran out of time)
    The standard brakes worked fine but I didn't punish them that much (knowing in the back of my mind they were standard). The Ferodo pads were great though.
    I bent the old cage when I rolled the old car, so it is a new seam welded shell with a new full weld in cage.
    Yes a full welded in cage stiffens the whole car and it feels completely different to a standard 205 or one with only a half cage.
    That said the rear beam and front struts only have group N hardened rubber mounts.
    The roll cage does not reach through the firewall to the strut tops as we decided it was unnecessary.
    The box section between the firewall and the strut top is quite rigid. So I am not really sure if having a full weld in cage will "make the suspension work" any better.
    1,100
    OK, I am sure you will love the new brakes once they are done.
    I have read many times that a car with significant body flex is pushed around by firmer springs, which need a solid bracing. I am guessing that the ride will become stiffer too. I presume you have a strut brace.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Awesome stuff! sounded great. What kind of exhaust system are u running?
    Geelong
    1,226
    Quote Originally Posted by pug-life View Post
    although its mainly induction u can hear i was curious anyway...
    Mar 2005
    Bridgewater
    19
    Yes I have a front strutbrace, the overall ride is quite stiff but not rock hard.
    We decided on not making everything rock solid, that might work on a smooth track but not so great for Adelaide roads
    The exhaust & extractors are custom 2.75 inch, muffler is no name brand but works just fine
    8,433
    And now for the really important question....
    What camera are you using???
    I like the images and sound and got quite a rise in pulse watching and hearing the clip.
    Jo
    1,100
    Being originally from Adelaide, I know what you are saying about the roads. Everytime I go back the goat tracks seem to get worse!
    I also noticed that your car looks road registered - I thought SA roads were super tough on modded cars. Perhaps you keep a low profile...
    Concerning your seats, did you weld in new mounting points on the shell itself? - the standard holes are too weak I find.
    Interesting the the full cage makes the car feel much different. I currently just have a bolt in half cage - no connection between the front and the back, just huge door openings and narrows sill...it makes sense.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    651
    Quote Originally Posted by Isis View Post
    Well done
    My record time is 18 minutes for Norton Summit.
    My push bike is fairly standard though.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    Mar 2005
    Bridgewater
    19
    The camera is a VIO POV 1.5, now superseded with the VIO POV HD.
    Camera on bonnet, ext mic in engine bay.
    The car is currently road registered, I plan on taking it through Regency on the CAMS DRC (Dedicated Rally Car Scheme) Then no police can defect me.
    I don't drive the car everyday, it's only for competition, so I suppose I do keep a low profile
    When I had the rollcage installed, I also had tube welded to the floor (with steel flat brackets) for mounting the seats.
    The original "hump" where the seats fit was removed as it was deemed too weak.
    Stage time was officially 5:41, 24th fastest out of 59 competitors and 1:41 over the base time allowed.
    (No one cleaned that stage, Weeks and Quinn were both 0:59 over the base time 0f 4:00)
    1,100
    Thanks for all the extra info.
    You might know Jim caudle? He's been around the Adelaide rally scene for yonks.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Mar 2005
    Bridgewater
    19
    Yes Jim's been around for a while.
    He rallied a beautifully presented Datsun 1200 in the Scouts Rally of South Australia this year
    Dec 2010
    Wollongong, NSW
    502
    hi Rallypug,
    You drove past our farm on the Cudlee Creek stage while we were watching, but I was confused by that stage. Half of the cars seemed to be out for a Sunday drive. Given that on the corner on the top of the hill most of the locals always sqeal their tyres and some of them come to grief during ordinary driving, why is it that almost no-one in the rally seemed to be going flat out?
    Jakob and I thought that maybe you were going the reverse way to check out the road before coming back, but then all the cars had gone and no-one came back? Was it a tame section or were you really competing?
    Regards, Erik
    9,290
    Navigated for Mike Ball in Peter Bianchi's 203 back in the mid 70s.
    I remember Mike? Hobby drove this car as well, it had a 2 litre 504 engine, he later won an SARC round in Peter's 504, with Endrust Rally director Ted Dobrynski navigating.
    Funnily enough Peter rang me today to see if anyone had ever put an auto box into a 203.
    I said that it had been done with a Holden motor but his customer wanted to fit one to a 203 motor!
    Graham
    1,100
    Love the 1200. That's just one of his many toys.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Mar 2005
    Bridgewater
    19
    Hi Erik
    Cuddlee Creek was a competitive stage, a new one for this years event.
    The fastest cars go last in Targa events, so the speed of the cars should have increased.
    If there's tyre squealing there's usually big problems as the tyres we use are very soft and don't loose traction much.
    The only other reasons for going slowly would be that the corner is after the flying finish, where we are off the accelerator.
