My gti is running hot. Opinions?
Results 1 to 7 of 7
    Jul 2011
    19
    Default My gti is running hot. Opinions?
    I've noticed lately that my 206 is regularly running above 90 on the temperature gauge. In traffic it is hovering up around 3 quaters but there is no overheating symptoms and the car seems to be running fine. On the highway it generally hovers around half/a bit below. Can anyone tell me if this is normal? Oh and I don't usually drive with the aircon on.
    Any help is appreciated
    Feb 2002
    Tamworth NSW
    496
    Icon7
    This may or may not be normal.
    Modern compact engines with electric thermo-fans tend to have higher temperatures in low speed or traffic type conditions.
    However, a check that I would carry out straight away is to confirm that the thermo-fans are in fact operating. Sometimes, if the sensor switch is faulty & the fan is not running because of this, then turning on the airconditioning should then engage the fan & help to control any high coolant temperatures.
    Of course, I assume coolant levels etc are OK? Also, that the front grill / radiator core etc is clear of debris?
    Kim.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,608
    Quote Originally Posted by KIMDEB View Post
    Kim.
    +1 to that. I am not that familiar with a 206, but I have had success with flushing of the radiator to make sure you are using the full cooling capacity
    Jun 2011
    17
    My GTi indicates around the 90 mark on occasion, the owners manual states that anywhere within the white markers on the gauge is fine and normal, problem only when the needle heads into the red.
    So as the others have said, if your levels are topped up etc.
    I would only get concerned if you see the needle start to climb pass the last white marker heading for the first red mark.
    Jul 2011
    19
    cheers guys,
    I did have it serviced only last week so the coolant was changed and yes the radiator is clear of any debris (I did double check just to make sure I wasn't the dumbest man alive).
    Seems like I'm worrying over nothing I guess? I'll have to see how it goes in the summer when the weather starts to really warm up
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by gti01 View Post
    cheers guys,
    Is the temperature behaving differently to before the coolant was changed? If so, I'd suggest the person changing it may not have done a very good job of bleeding the system.
    I think the needle sitting at three quarters is a little high, but then I always had the climate control on and that means the fan is always ticking over.
    It's certainly still well within the "OK" range, but it really only goes there when you've been driving in a spirited fashion (or for a while on a motorway) and the oil temp is up.
    Have you checked that the fan operates?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jul 2011
    19
    gday simon,
    No I only really started to notice it a couple of weeks ago before the coolant was changed, thought the coolant change might make some sort of difference but it hasnt.
    The fan does definately work when the air-con is on but I never usually drive with it on. Maybe I'll have to start doing so and see if it runs cooler? I'll keep an eye on the oil temp in future as well (didn't even think about that). I don't really drive it in a 'spirited' fashion at all apart from the occasional traffic light grand prix.
