306 Cooling Fans Control Unit
Results 1 to 11 of 11
    Member jason's Avatar
    Jan 2011
    64
    Default 306 Cooling Fans Control Unit
    Hey Team,
    2001 306 XT 2.0L
    Fans aren't coming on when at 100 or even when air con is turned on, and it's been suggested it's the fan
    control unit, found under the passenger headlight inside the bumber.
    It's a $125 part to buy, so before I do, penny for your thoughts?
    Jase
    1000+ Posts stuartb's Avatar
    Apr 2002
    somewhere over the rainbow
    1,445
    is one only coming on?...they run in series for low speed, so if one motor is out no fans at all, then 1 only comes in at full speed...the brushes in these motors go all the time (a xantia a 306 and a 406 I owned ALL of them has this happen)...I get brushes from an auto electricin and cut them to size for about $10...they bastards to get out tho, I cut a double ended ring spanner in half to get to the rear 10mm nuts, then you have to pull the "non rebuildable" fan motor apart...
    Jan 2011
    64
    Quote Originally Posted by stuartb View Post
    Unfortunately, it's no fans at all. Good to know about the brushes though. Thanks.
    Apr 2002
    1,445
    did you do the test where you remove the green(I think by memory) connector on the thermostat housing and turn the ignition on and the fans go slow then fast to test all is working?
    good explanation here
    http://www.peugeotlogic.com/workshop...an2/fanop1.htm
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    also check the fuses.
    it will be one of the fuses under the bonnet on passenger side.
    If one of the motors is gone, they sometimes blow the fuse.
    Feb 2001
    Romsey, Victoria, Australia
    4,879
    Quote Originally Posted by jason View Post
    Hey Team,
    2001 306 XT 2.0L
    Jase
    We have second hand units in stock for less than half that price.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    check to see if the fans come on with the ac switched on. if yes, look elsewhere. if no, replace the control unit, then the fans. after your standard power/fuse/relay checks
    Jan 2006
    North West Tas
    46
    Hi there,
    I was having trouble with the fans on my 405 SRDT when this link was posted for me.
    It may be of assistance for you perhaps.
    Jan 2011
    64
    Ok, so I've made some progress. I changed the control unit over, turned the air con, but no fans. I was gutted. Then... I turned the fans by hand and hey presto, fans started spinning. So happy. So, it may have been the control unit, but until I put the old one back in, I won't know. In the meantime, I gonna hope it's the brushes being temperamental and not the bearings that are "seizing" the fans. Shall update ASAP.
    Does anyone have advice on getting them out?
    Dec 2005
    HOBART
    1,265
    You'll have to remove the front bumper and grille. I have prepared a repair data sheet on the fans which I can send you if like. It's an MS Word document.
    Email me at [email protected], and I'll send it to you.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    May 2011
    melborne
    364
    This is a sign that the fan motors are on there way out, so I'd say your old control unit is still good.
    To change the fans, you'll have to remove the bumper and grill (as already mentioned).
    This is tricky because its vary easy to brake the plastic clips around the grill and headlights.
