Mi16 cam seal
Thread: Mi16 cam seal
    1,376
    Default Mi16 cam seal
    The seal on the cam shaft that operates the power steering pump - is that the same as a the camshaft seals on the pully end of the head?
    I have not had it apart to check and the manual does not clearly denote it. I have oil seeping everywhere from that area. I have just replaced the rocker cover gasket and now its worse.
    Thanks,
    7,487
    No, same size but different direction. So there are four different cam shaft seals in the head.
    1,376
    Sorry Peter, I don't understand. I can only see three. One for each end that houses the cam belt gears and one for the power steering pump pully wheel. Where does the other go?
    7,487
    inlet cam - pulley end + dizzy end
    exhaust cam - pulley end + PAS end
    On the XU10J4 there are only two, on the pulley ends.
    1,376
    Ok Thanks Peter, I'll start chasing some parts.
    ...also can you PM me your account details so I can purchase the DIY oil pump extension & cam key. I might as well have a play with that whilst everything is apart.
    Thanks.
