Which wheels will fit??
Results 1 to 15 of 15
    Aug 2011
    184
    Default Which wheels will fit??
    Evening all, I have a S1 205 GTI which is currently wearing a set of steel rims and I think Mitsubishi Sigma hubcaps. Before you tell me how obscene and wrong that is I must confess that I have just bought it and it was already like that!
    My question to you all is other than the 14 and 15 inch Speedline wheels, and the Mi16 what other cars share the same stud pattern and ideally offset?
    My preference would be to fit S3 GTI rims or Mi16 rims but am considering my options.
    Any advice would be welcomed. Thanks
    9,290
    Quote Originally Posted by Jezwillow View Post
    Mi16 wheels are set too far in and will touch the inner wheel arch at the rear. 306 wheels have the same problem.
    405 8 valve wheels are OK.
    Graham
    Aug 2011
    184
    Thanks Graham. Much appreciated.
    Fellow Frogger! deltone's Avatar
    Perth
    390
    15" 306 xsi/s16 wheels fit fine on my gti with drums brakes at the back
    Also another set of 306 rims fit fine, unsure what model the are off but the are 14".
    I think the stud pattern is the same as some of the fords, includimg cortina. Maybe the older fiesta?
    I had a mate with pug 15" speedlines on his ford cortina,,, looked preety good althou i wasnt too happy lol
    205 GTi T16
    205 CTi
    Aug 2011
    184
    Quote Originally Posted by deltone View Post
    Thanks Deltone.
    Now I juest need to track down some wheels.
    9,290
    Maybe different to the 306 14 inch steel wheels which are what I had tried? Also, maybe you had fitted them to a series 3?
    Graham
    Perth
    390
    well my car is a 1989 Gti S2, with drums at the back,
    im sure the S2 has series one rear beam and front suspension.
    The 205 Si with the 306 14" alloys that i have is a 1992 thou.
    205 GTi T16
    205 CTi
    9,290
    I tried my Si with 306 steels and didn't have any luck, I guess you need to just give it a try and see whether they fit.
    Graham
    Dec 2010
    canberra
    206
    dont most european cars from the mid-70s- late 90s with 4 stud wheels share a special ' euro ' pattern. not sure if its true, read it in a magazine once. hope this helps
    cheers
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    +1 on the back for s16 on a drum rear 205.
    on the front i had to roll the arches, mostly because it is very low, if you have a closer to normal ride height and stiffish springs and dampening you will probably be ok.
    195/55's will touch the inner chassis on full lock with a 6" correct offset for a 205 wheel, 195/50's i am hoping will clear ...
    sunny coast
    263
    306 s16 15x6" et26? IIRC on my 205
    1000+ Posts djvu205's Avatar
    1,402
    Spar they look more like gti6 rims, are the s16 ones the same?
    Perth
    390
    Yea they are gti6 wheels, the s16 are different, not sure if there is a difference with offset thou
    These are s16 rims, this was the quickest easiest pic to find lol
    These rims fit on my S2 with no modifications required.
    If i was on my computer id post you a pic of what they look like on the gti itself, i will upload a pic later on.
    http://img.swapz.co.uk/swapz/2011-05...6a47e719_2.jpg
    205 GTi T16
    205 CTi
    Perth
    390
    Btw spar the gti6 rims on your car look awsome, especially the way the front line up with the guards!!
    205 GTi T16
    205 CTi
    sunny coast
    263
    cheers, yeah i thought they looked good, especially as the 5 of em only cost me $270- including near new potenzas
    i had to roll the front arches to get them to line up (and clear), about 15mm, so as standard the wheels would poke out a little past the arches.
    re: gti-6 vs s16 - i saw some on a 306 cab so assumed they were s16 fitment, now not so sure
