Seat belt won't unlock, 505
Results 1 to 11 of 11
    1000+ Posts okalford's Avatar
    Sep 2004
    10,968
    Icon11 Seat belt won't unlock, 505
    This might seem a trivial issue but I'll ask anyway. The drivers seatbelt on my 505 (GTi, series 2) has locked in place and despite efforts to fiddle with it I cannot get it open. Being a retractable belt I have been slipping it over my head for now but it means no lap belt part is in use and it wouldn't be 100% safe or roadworthy.
    Is there a trick to getting them open when this happens? So far I can't see how I could even disassemble the locking part to get it open that way. I guess I might need to replace the entire seatbelt unit?
    lost
    11,055
    Icon6
    G'day,
    it means that your car loves you so much, it wont let you go.
    or
    have you seen the film 'The Cars That ate Paris'
    I have this vision of you being one with your car..
    Attached Thumbnails Attached Thumbnails Seat belt won't unlock, 505-cars-ate-okalford.jpg   Seat belt won't unlock, 505-cars_that_ate_paris_movie_poster.jpg
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Dec 2002
    Menzies Creek
    2,542
    Sometimes the passenger seatbelt in my 505 locks (usually with the girlfriend in the seat!). Every time sofar it has been because it hasn't been pushed in properly. So as much as she fiddles with it, she can't get it undone. I simple lean over, push the seatbelt in all the way (usually takes a bit of a shove to get it to move), and then it unclips as usual.
    I hope your problem is as simple!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    5,312
    Yep, can be a little frustratin' .....
    http://www.youtube.com/watch?v=sK9T4sxwHUA
    Mike.
    Started out with nothing, still got most of it left.
    Sep 2004
    10,968
    Quote Originally Posted by catshamlet View Post
    Mike.
    Thanks Mike....
    Written from my lap top, been stuck in the car for three days now ...
    I had another fiddle with it today, and a blonde moment where I thought to swap the drivers side bit for the passenger side one but then it would still be stuck, only to the passenger seat fitting. Tried lubrication but no luck, might have to break it open!
    It's the little things in life.....
    Fellow Frogger! James S's Avatar
    Aug 2002
    345
    Default 505 Seatbelts
    Yep, my 505 GTI wagon driver's side belt gets stuck also. Mine has a loose piece in it which fails to move horizontally out of the way when you press the button sometimes. I think that it is spring loaded. I get it undone by knocking the whole thing sideways against the centre console to make that bit move. It tends to work. I do have a number of spare seatbelt bits though and so I should just replace it.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Empty a can of contact cleaner into the assembly and let dry. (jiggle and see if it moves).
    Then puff into the slots.... lots of graphite, (yes its messy but it worked for me when mine stuck). Wipe off excess an look for a replacement latch unit. (generally the passangers side is used less and is in better condition than the drivers one).
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    1000+ Posts michaelr's Avatar
    1,393
    Around $120 for a brand new belt, less 10% discount for Aussie Frogs members if you choose to shop at SeatSafe.
    Seat Belt discount for Aussie Frogs members
    Michael
    Member, Citroen Car Club NSW
    Dec 2005
    HOBART
    1,265
    This is a very common problem. Funny how Series 1 seat belts are much better designed.
    I have a spare stalk if you need it.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,260
    Mike.
    When I played the youtube clip it had a recommendation for the clip in Pulp Fiction regarding Jules' wallet the BMF one. Anyone of the AFers able to direct us to a source of 'Bad Mother Froggers' wallets if possible!
    Of course with a beautifully coloured amphibian Pond mark.
    p.s. Thanks Mike you always seem to bring a smile to this hairy face.
    Sep 2004
    10,968
    Quote Originally Posted by pugnut1 View Post
    Thanks pugnut1, I am interested as discussed by pm.
    Here are some pics of mine as promised incase they do vary.
    Kaye
    Attached Thumbnails Attached Thumbnails Seat belt won't unlock, 505-stuck-belt-505.jpg   Seat belt won't unlock, 505-505-seat-belt.jpg
