604 Oil level question
Results 1 to 11 of 11
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    555
    Default 604 Oil level question
    I do not have the correct dip stick for my new V6 engine .Its a Volvo dip stick tube and I have another dipstick that seems to fit in the tube
    Would somebody know how much oil a 604 requires to be at the max mark after draining the sump but not removing the filter. Then I could drain and measure in the oil and mark the dip stick at the correct spot.
    Or could somebody measure the length of a Volvo 2850cc dip stick
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    12,273
    Quote Originally Posted by Rally View Post
    they take 6L in the sump
    6.5L including the filter
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Aug 2005
    Athens, Greece
    661
    The upper oil level notch in the works coupe is at 440 mm.
    We only use six liters and that includes the oil cooler.
    Pearl Beach NSW
    555
    Thank you for the prompt replys
    Will drain and refill with six litres and mark the stick.
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    con
    con is offline
    sydney, nsw, australia
    521
    Rally,
    The correct level for the PRV is shown in the attached page; Bit hard to read but it says - sans filtre 6.0L, avec filtre 6.5L. I can send you a higher resolution copy (and the other pages) if you PM me your email address.
    Con...
    London, UK
    294
    I think mine takes about 6 litres after oil and filter change. The filters don't seem very big though.
    con
    con is offline
    521
    I do not have the correct dip stick for my new V6 engine. Its a Volvo dip stick tube and I have another dipstick that seems to fit in the tube
    Rally,
    I'd hate you to see you get into strife....
    The dip stick markings on my geniune Peugeot PRV (ZN3J - 2849cc) are 54cm and 58cm (from the top of the tube). The dipstick and the tube are original. They may well be different for the 2664cc (ex 604s).
    con....
    Aug 2005
    Athens, Greece
    661
    Quote Originally Posted by con View Post
    Rally,
    con....
    Mine is a works engine, so the dipstick tube may be modified/shortened. I think the safest option will be to fill with 5 liters and mark the dipstick, then add another liter and mark again so you get a range.
    con
    con is offline
    521
    Default Oil Level
    Rally,
    con....
    I am sorry but I just can't help myself.....
    con....
    Aug 2005
    Athens, Greece
    661
    con....
    I believe all the numbers are in agreement, con, 6 or 6.5 liters depending on whether you change the oil filter. Mine takes only six because it has a gated, slighlty raised internally, sump.
    con
    con is offline
    521
    Quote Originally Posted by Thanos View Post
    Thanos,
    I think we've finally got to the bottom of the discrepancy: There seems to be a difference between the Volvo and the Peugeot variant of the 2849cc PRV.
    I have in front of me the Volvo 760 v6 Workshop Manual. And, guess what? The capacity of the Volvo 2849cc PRV is quoted as:
    - engine only is 5.5L
    - engine and filter is 6.0L.
    So, obviuosly Peugeot use an extra 0.5L in their ZN3J (2849cc) engines.
    con....
