Removing MI16 Head. Torx t55?
Results 1 to 9 of 9
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,314
    Default Removing MI16 Head. Torx t55?
    Just about to remove the head on the S16. Cant seem to locate my Torx bit to get it off. Is i the T55 im after or T50? 2.0l Mi16 FWIW
    Cam
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    7,427
    T55, buy SnapOn.
    Dec 2010
    Sydney, AUS / London, UK
    3
    Snap on is the only way to go, although they might only have a t55 in 3/8 drive.
    When I did my bolts, I used a snap on t55 and 3/8->1/2 converter with a snap on 18 inch breaker bar... Broke two no-name t55's and a 1/2 inch breaker bar from a decent name before I went to snap-on.
    Good luck, and don't sweat if you break bolts
    Nov 2003
    Bondi
    3,314
    Where can i buy snap on from?
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    7,427
    I have both 1/2" and 3/8" SnapOn T55's. The only issue with the 1/2" model is that you need to turn down the OD so it fits in the head. I can do that for you. Ring SnapOn and they will send around the local rep in a van.
    Nov 2003
    Bondi
    3,314
    Hey Pete.
    I work next door to the Lamborghini garage in Darlinghurst. Dropped in there this arvo for a chat with the young apprentice and he lent me one. Ill buy one for down the track but until then ill try not bent the Lambo one!
    Should have a pick or two up tonight of the head.....
    Cam
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    Nov 2003
    Bondi
    3,314
    Anyone interested in what happened tonight with the head removal have a look in the technical section
    Cam
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    Feb 2011
    Hornsby NSW
    148
    Hey Cameron - I owe you for identifying this same tool bit earlier this week when I was almost shafted on the Hume Highway south. Scary to hear that they can be busted. My close mate is a SnapOn franchisee, but I hadn't considered going ultra-tech. Just after the mishap, I met the local SnapOn guy in Euroa, but at that stage I didn't know the precise size. But snapping bits as well as a breaker bar! As you noticed recently at my place, I have been pulling apart a crunched Gti 180, and in the course of that, was astounded how much torque is on those caliper bolts; must be 70 ft/lbs (500Nm ?) on quite a small area. In my emergency, I used a bit from a set I bought in Bunnings at Broadmeadow Vic (Kinchrome) with a 3/8 ratchet directly on the bit, which was embedded in a socket. No extensions, and half a metre of pipe. They are really tight (and have an interference thread just for good measure) but once I cracked them it was just a stiff half turn at a time 'til they slacked a bit and wound out.
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Quote Originally Posted by 306cabmad View Post
    See..... THE RETURN KEY!!!! - - how was that for shouting!!! (see other thread)
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
