205 rear independant suspention?
Results 1 to 7 of 7
    Dec 2010
    canberra
    206
    Default 205 rear independant suspention?
    hi guys ive stumbled apon a car on ebay with this strange rear set up.
    http://www.ebay.co.uk/itm/Peugeot-20...item1e6552782d
    and has anyone i oz done a conversion like this?
    Fellow Frogger! deltone's Avatar
    Perth
    390
    The 205 already has indipendent rear suspenion. This car has the ability to fit coilover rather than the standard torsion bars and shocks.
    205 GTi T16
    205 CTi
    Dec 2010
    canberra
    206
    thats what i ment.....
    ive never seen it before
    Fellow Frogger! Binky's Avatar
    15 Credibility st. Nth Fitzroy, Vic.
    227
    I'm having trouble seeing what benefit could be gained by towers rather than the original torsion spring set-up, particularly as it is so easy to adjust spring tension with the original design...
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,316
    I think this car ( look to be anyway ) made by Sandy brown. When complete by Sandy these car run Coilovers at the rear with NO Tortion bars and NO arb. Apparently a very good modification although an expensive one. If you look on the 205 gtidrivers site Sarty Evo 2 has a similar chassis and was a beast
    Cam
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    Perth
    390
    Quote Originally Posted by Binky View Post
    Probably allows you to tune the rear suspension more easily and precisly?? Also the supension tower is placed right above the original bump stop on the trailing arm, wouldnt this change the suspension geometry? Or at lest the dynamic operation of the suspension since the shock and spring is now in a different leverage point?
    205 GTi T16
    205 CTi
    227
    Quote Originally Posted by deltone View Post
    I thought it would make tuning the rear suspension more difficult (dis assembling and re assembling coil overs) but I admit it may give more precision to adjustments...
    I also wondered about the change in geometry. The trailing arm swing (in my imagination - at least) seems to be better geared to coping with the rearward forces of racing over bumps...
