Timing Belt Replacement
    Jun 2011
    Adelaide/South Australia
    28
    Default Timing Belt Replacement
    I have been looking through the paperwork when the car was bought, then when the
    First Timing Belt Replacement was done.
    Vin VF3 2 C RFN F 41973195
    2001 206 GTI 2.0 16v
    28 1 2002 Bought New, but not by me
    Timing belt changed
    16 6 2008 at 90908
    What is the longest or best time anyone has changed their Timing Belt.
    It look as though it will be due June next year.
    Thanks in advance for any reply's.
    Ed
    May 2004
    wollongong
    40
    Default timing belt
    The rule with 205s is every 80,000 kms which is the same as my 2ltr C4.
    I believe some recommend it be done every 80k or four years, although I don't know how critical the 4 year time frame is.
    Before I changed my 205's belt, the previous owner had left it for six years and the belt was still intact (and looked ok when it came out).
    Jun 2011
    28
    Timing belt changed
    16 6 2008 at 90908
    The Timing belt has only done 40400 in 3 years.
    I only do about 150kms per week.
    I do drive sensibly.
    So i will only do about 30000 in the following 4 years
    So what are my best options now replace every 4 years or?
    I have been searching for a replacement belt.
    Ready for next year
    I have found the Dayco and Gates belts.
    Are both belts good or does anyone have a preference
    Ed
    2001 206 GTI 2.0 16v[/QUOTE]
    Fellow Frogger! Atan's Avatar
    261
    it's usually 80,000 km or 4 years whichever comes first. from all accounts it's not the distance but the aging of the belt whcih creates cracks in the belt etc or the tensioners and pulleys fail over time
    2007 VW Jetta 2.0 TDi 6sp manual
    2001 VW Bora 4-Motion - flooded away
    1998 Peugeot 406 SV manual - Gone to Hail Heaven
    1994 Silver S16 - Gone
    1983 505 Sti - Gone to good home
    9,158
    There's more than just the belt. Tensioner, water pump, etc, all have some impact on how the belt goes through it's life cycle.
    Given the expense if the belt fails, I think it's cheaper to do it and associated hardware every 4 years as cheap insurance alone.
    Any mistake or part quality shortcomings when doing the belt will impact on its lifespan.
    One example is poor quality bearings in tensioners (or incorrect tension applied) which can cause the belt to run on the edge of the pulleys rubbing and fraying, or can cause the water pump to fail early, and so on.
    ACHTUNG ALLES LOOKENPEEPERS
