404 oil filter
Results 1 to 23 of 23
Thread: 404 oil filter
    jervis bay nsw
    183
    Default 404 oil filter
    could someone tell me the correct Ryco oil filter no for an early 404 ? I obtained a Z142A but the thread is larger,I believe it fits the later motors. Thanks Max
    18,745
    Quote Originally Posted by Maxy View Post
    The Ryco filters for the screw housing on the 404 are Z69. These fit 1969 and 1970 disc brake cars.
    However Purflux 152? are a far better filter and are obtainable from Caravelle Imports or EAI. I would not use a Ryco filter personally.
    If your car is a earlier than 1969, I believe the early 403/404 cartridge type filters (the type with a "bowl" over the filter) are unobtainable.
    Peugeot Car Club Vic have a member who does a modifications to accept a screw on oil filter.
    The other option may be to fit a later a oil filter housing with the screw on filter the same as 504 and XN 505. You would need to make spacers to refit the dynamo.
    I'm not sure if the filter housings are directly interchangeable on the block, as far as I know they are.
    You have me confused with "early" because the early models had the cartridge type filters.
    anywhere
    1,682
    The early cartridge filters are available on ebay at high cost from Argentina.
    18,745
    Quote Originally Posted by Russell Hall View Post
    Thanks for the info Russell. I was unaware.
    jervis bay nsw
    183
    the car is a ''66 but could be a different motor--it has the early type dipstick (not extended)--definitely a screwon filter, a blue French made coded LS152B, but a smaller thread than the later filter. sounds as if the Z69 might be right. Thanks.
    Feb 2001
    Romsey, Victoria, Australia
    4,805
    How many times have we talked about the dangers of non genuine filters? Stick to LS152B it isn't hard.
    We have them in stock for $16.50 but there available from every Pug specialist.
    We've talked about those filters not holding oil pressure, but a workshop near me used to service a 504 and one day they asked me how do I stop the filters leaking oil, they said that no matter how tight the tighten them every filter they fit leaks.
    My answer was, we only use Purflux, they fitted one and no more oil leak.
    Why do people insist on using non gen?
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Oct 2005
    Rome
    2,660
    And at $16.50, there is no financial reason to buy inferior either...
    Dave
    ​1997 BMW K1200RS
    IR655
    18,745
    Quote Originally Posted by David Cavanagh View Post
    Quoted from post #2
    However Purflux 152? are a far better filter and are obtainable.....
    Apologies Dave, I'll put you on the supplier list next time. I tend to think of you business as a used car parts supplier.
    I wouldn't have a Z69 on my mind let alone an engine.
    However, the decision lies with OP.
    Perth Western Australia
    2,672
    The Ryco Z69 filters are now made in Seth Efrica. Almost $30 last time I looked !
    The only oil filter I had that leaked was a Ryco Z69.
    While it's stuck in my brain. R267P was the number of the Ryco element type filter on early Peugeots.
    9,137
    I bought a Ryco fuel filter for my Si, made in China.
    Graham
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,702
    Chinese filters, they screen out particles to 7000 microns, eh?
    Peugeot ordered a large run of new 203-403-404 filters from Purflux a few years back and I bought 15 or so, maybe they still have some??
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    anywhere
    1,682
    The Peugeot dealers in Australia have no interest in supplying parts for any but the newest cars. I did try a big organization once as to what parts they could get for the 203. They never rang back which I think said it all. The main aftermarket supplier of parts (EAI) simply says the filters are unavailable. Hard to believe given the number of cars still in existence which require the cartridge. In the 1970's the concessionaire, Renault Australia, would go to a lot of trouble chasing parts for old or rare Peugeots. Different times.
    18,745
    I was amazed that last year Regan's got me some parts for 404 wet struts, the exact part escapes me at moment, it took 5 days from France. The price was reasonable considering the delivery method and rarity.
    The key to getting it was to give them a Peugeot part number, after that the computer does the rest.
    They have no listing of early part number locally, but search Peugeot stock once they have the number.
    anywhere
    1,682
    Regans was the place I tried, I thought if anyone could find out what early parts were available they could, but they just weren't interested.
    Around 1974 a bloke in Tasmania got in touch with Heidelberg about parts for a 202 he'd found. Needed just about everything. Nothing was held here so they got in touch with New Caledonia but nothing there either. They contacted Peugeot in France who couldn't help with new parts but arranged the supply of everything needed from a wrecker. Now that was service from an organization that could be bothered.
    Northern NSW
    1,033
    Is the 404 cartridge the same as the 403/ 203?
    I just ordered one from here:
    http://www.veteranen-fischer.de/scri...dex.php?lng=en
    16.82Eorus.
    anywhere
    1,682
    It is indeed. So I wonder why they are unavailable in Australia.
    9,137
    They have probably got a lot of old stock.
    They also have engine bearings for 403/203 wonder if that is NOS or new production.
    No one has diff seals unfortunately, this is going to be a real problem in the future, even for the 60th Redex Rerun in 2013.
    I gave a good used seal to Don Tracey on Friday so he could do the Cape York trip in his 203 panel van.
    Graham
    Fellow Frogger! Commerciale's Avatar
    Dec 2010
    178
    Neoretro has diff seals (if you mean the graphite one on the nose of the worm). I got one from them recently.
    Nov 2005
    Geraldton
    1,542
    Graham
    Graham
    What are the dimensions of the diff seal?
    P
    In the Shed(s):
    In the Past:
    9,137
    Quote Originally Posted by Commerciale View Post
    That's the one I ordered one from Neo Retro a couple of months back and they couldn't supply.
    Hopefully they have them back in stock?
    9,137
    Graham
    P
    They are a special spring loaded graphite type seal, I have tried bearing supply places and no one had seen anything like it.
    Bit like a water pump seal.
    Dec 2010
    178
    I will be in Paris early next week. I can check with Station 50 (Neoretro's retail outlet in Paris).
    9,137
    That would be great, thanks.
    Graham
