406 suspension
Results 1 to 8 of 8
Thread: 406 suspension
    wid
    wid is offline
    68
    Default 406 suspension
    Still chasing noises in the front end.
    So far I have replaced sway bar links and lower control arm bushes.
    Still, everytime you hit the accelerator and take off there is a clunk. The engine mounts look fine.
    Has any one had the need to replace the lower ball joint.
    If so what were the symptoms.
    Fellow Frogger! 908HDI's Avatar
    May 2011
    Gold Coast, Australia
    380
    I would get a friend to put the car in first and reverse with a bit of throttle and the brakes on with the bonnet up, while you look and listen for the clunk [ from the side of the car ].
    The other way is to take it to a garage for them to identify the problem and give you a quote at least then you'll know what it is.....
    tweed heads
    1,502
    Default gearbox mount
    have you checked the mount above the gearbox ,its under the battery on a 405 but i suspect it will be in similar place on 406 .PUGS
    Armidale
    49
    Default 406 clunk
    I replaced the lower engine mount and retorqued the upper engine mount bolt (drivers side near cambelt cover) this bolt is removed to replace cambelt and tensioners
    KC MI16
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,868
    If it's doing it under acceleration etc - i'd suggest that it would be the mounts! Try stabbing the pedal...?
    As for the front end - i'm planning on rebuilding mine soonish. Will let you know how it goes. It's still fine, but after 190k - time for a refresh!
    2005 Renault Clio 182 Cup
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,777
    Check the strut inserts/top mount as well - is it a clunk there as the nose lifts under acceleration?
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Tie rod ends? hows the steering?
    I had such a clunking noise.
    It was the linkages... made huge difference.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    129
    Default 406
    hi
    yes ihad the same noise ,replaced tie rod ends and its gone
    cheers ron
