505 STI to 505 GTI engine swap
Results 1 to 9 of 9
    22
    Default 505 STI to 505 GTI engine swap
    Hello Froggers,
    I'm Looking for some tips on an intended engine swap.
    I have a 1984 505 STI manual with a dead motor and have aquired a 1985 505 GTI automatic with a good motor and rotten body. Am I likely to encounter any difficulties such as;
    a) Adding the GTI computer to the STI?
    b) Connecting the GTI motor to the STI 5 Speed, e.g. splines on input shaft, bellhousing?
    c) Anything I haven't thought of?
    Any advice would be appreciated.
    Paris
    Dec 2002
    Menzies Creek
    2,541
    It will be pretty straightforward, I've done this swap before.
    Being similar year cars, the wiring plugs for the engine will be fairly straightforward, I think I had to relocate and rewire the ignition relay to provide power to the ECU. The studs to bolt the ECU behind the glovebox are already there, and the holes in the firewall for the loom are already cut. You don't need to change the fuel pump.
    If you're happy enough with the STi system, all of the injection gear on the STi is completely compatible with the GTi motor, you could just change the 'core' over and be done with it.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    9,283
    Quote Originally Posted by Paris View Post
    Hello Froggers,
    Paris
    You will need to add a bearing in the back of the crankshaft for the gearbox input shaft.
    You will need to use a GTi engine wiring loom, may get complicated.
    I converted an STi to GTi but used aftermarket ECU so just added what I needed and left the STi loom in place.
    By the way the series 1 GTi ECU is under the dash pad!
    Graham
    22
    Thanks for the tips. I want to change to GTI system because the STI system is already in bits and the GTI system is known to be working and seems simpler.
    Good tip about the bearing. Is that a plain bronze bearing? How hard is it to remove it from the old engine or do I have to get a new one? I assume the Crankshaft will already have the socket drilled?
    9,283
    It's a ball bearing, just buy a new one.
    Graham
    9,283
    Quote Originally Posted by Demannu View Post
    Thinking of a series 2?
    The series 1 ECU is under the dash pad.
    Graham
    Dec 2002
    Menzies Creek
    2,541
    Graham
    Ahh, good point. Yes, there's a 'clamp' thing under the dash pad to hold it up there. Not sure if that will be fitted already to the STi.
    Spigot bearing size 40mm OD x 17mm ID x 12mm thick. Get a sealed bearing. You can get them from CBC for about $8 (last time I got one).
    Scotty
    Lilydale, Melbourne
    2,095
    I removed the ECU from a series 1 GTI. I didn't have to remove the dashboard. I think the clamp stayed, I just took the ECU. Got to it from above the passenger footwell area.
    John W
    1974 Peugeot 504 TI
    - now on the road
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by peujohn View Post
    Yes, that's right, there's no need to remove the dashboard. It is clamped directly underneath the dash pad, but you access it from below. It is infinitely simpler if you remove the glovebox first, especially if you are taking the loom as well.
    The wiring loom runs from the ECU back across the firewall to a grommet in the passenger's side top corner of the firewall, except for one thick, green shielded wire that runs across to the dashboard for the tacho and a couple of short earthing leads. The grommet is big enough to cover a hole big enough to pull the entire ECU connector through.
    Scotty
