205 GTI driveshaft support bearing
    9,007
    Default 205 GTI driveshaft support bearing
    Is the supporting bearing on the RH driveshaft replaceable? If so, does the inboard joint have to come apart or is the bearing supposed to come out somehow at the gbox end?
    On my car it looks like there is a retainer in the way. Not sure if that comes off somehow.
    ACHTUNG ALLES LOOKENPEEPERS
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    Two bolts hold the bearing in. Also I think the bearing needs to be pressed off. But it most certainly can be replaced.
    9,007
    I am interested if it comes off the shaft, not how to take the driveshaft out of the car. I figured that one on my own.
    8V'ville
    919
    Quote Originally Posted by DjB8V View Post
    Try that
    Wollongong
    24
    The bearing will come off fairly easily, however you must get the retaining collar off first!
    I used gentle heating flame so I could resuse the collar!
    The bearing is a 60062RS C3 - Cost about $15 bucks from a bearing supplier (use FAG, Timkin or SKF Bearing)
    Regards
    9,007
    thank you Bootou. I'll give it a shot.
