205 heater smell
Results 1 to 13 of 13
    1000+ Posts Isis's Avatar
    1,100
    Default 205 heater smell
    My air system, whether on 'heat' or not, smells a bit unusual. Is it likely that the matrix has a small leak? I think the smell is coolant-like. Could the smell be generated before it goes through the matrix box?
    I am prepared to have a crack at cleaing out the whole system - any pointers?
    ta
    I
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Melbourne Australia
    1,382
    The obvious question, have you just noticed this change or has it always been there ?
    Next the only way you should get a whiff of coolant is if there is a leak somewhere. Check bulkhead hoses on outside for leak then move to inside under dash behind centre console.
    My heater matrix let go without warning and dumped it's contents in the passenger footwell. Easy to replace in a Series 3 without dismantling dash. Good luck.
    1,100
    I think it has always been there. I would have expected a small leak to become a big one quickly too. I just wonder if the hoses etc are now a bit ancient. hmmmm
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Jan 2011
    Rokeby Vic.
    10
    My 307 had a bad oily exhausty unburnt fuel smell for some time then stopped.
    It only came up when it had been running for a bit with the demister on during cold mornings.
    Turned out to be the AC evaporator coil leaking AC gas into the air into the cabin.
    Very expensive to repair - worth about half the cost of the car... $2,500 was one quote.
    So now I just drive the old triton ute if I need AC.
    Jul 2003
    222
    A 307 is only worth $5k now?!
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    May 2004
    Melbourne, Australia
    228
    If it is a coolant like smell then the heater matrix has a small leak.
    Try a bottle of Nulon R50 radiator stop leak. (the heater matrix is a little radiator after all)
    I have used it on 2 cars with this problem and it worked well.
    spiz
    1,100
    thanks Spiz, what do you think of your clio 197?
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    May 2004
    228
    Quote Originally Posted by Isis View Post
    A sensational package!
    This vid sums it up:
    http://www.youtube.com/watch?v=TG3YfBJUHec
    spiz
    1,100
    do you have those Recaros? can I have em if you prang it?
    all the RSC's are as much fun as each other I think but the latest shape looks the best IMHO
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    May 2004
    228
    No recaros in my one, is not an R27. The ride is stiff enough!
    spiz
    Jan 2011
    Rokeby Vic.
    10
    Quote Originally Posted by Langers View Post
    Um yeah I would not expect much more for it given it is getting a bit rough now and has 273,000kms on the clock.
    But if you want to pay me more for it then, yes thank you I will take your money.
    I will probably keep it for another year.
    Martin
    Jul 2003
    222
    Jeebus feels like yesterday that the 307 was released. Hard to comprehend one having 270k kms.
    1992 205 Si
    1000+ Posts Beano's Avatar
    3,147
    I had some cockroaches living in my heater ducts once....it is an odd smell......
