Best place to run amp power cable on 206
    Sydney, Australia
    526
    Default Best place to run amp power cable on 206
    Hey people,
    I am guessing a few people here have done it before, so what is the best place to run the power cable for an amp (assume 4 gauge cable) to the boot of a 206 gti 180? Are there any grometts that will allow access through the firewall?
    Cheers in advance
    Bad_Karma
    "The great philisopher Bashra once said... A flute without holes is not a flute, a donut without a hole is a danish" Ty Webb, Pro Golfer, CaddyShack
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    There's a black plastic type grommet that you can drill out. You need to drop the glovebox lid to get to it. It comes out on the engine side of the firewall just behind the wheel arch.
    This thread might shed more light. http://www.peugeot206cc.co.uk/viewto...rewall#p108713
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Half way between Brisbane and Ipswich
    235
    In my 206, I just ran the cable tucked into the plastic center console, then under the carpet through a hole near the back of the passenger seat, then under the carpet to beneath the rear seat base, then straight into my amp.
    An alternative is under the rubber trim next to the passenger door, then under the rear cup holders to the amp in the boot.
    Also, there's quite a bit of space in the ceiling, and the pillar trim easily pulls off.
    Note that this was in a GTi with the right gauge wire for a 400w RMS amp (it's about 4mm across the copper). If you want any thicker cable than this I doubt you can hide it anywhere between the center console and the rear seat base.
    Also if you need a grounding point, there's one behind the carpet on the left of the boot, just above the wheel arch.
    Sydney, Australia
    526
    Cool, thanks for the responses.
    Yeah I think I'll run the cables from the engine bay, via the grommet and down the passenger side sill into the back. I'll check out the grounding point too!
    Bad_Karma
