406 Operating Temperature
Results 1 to 8 of 8
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    Default 406 Operating Temperature
    The temp gauge on my 406 2l petrol D8 usually stays at 70C or below when cruising on the open road on a cool (15C-20C) day. Is this normal or is the thermostat stuck open?
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Sep 2003
    North Parramatta
    3,997
    Well, I don't think it's normal
    There's a good chance the thermostat is dodgy.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    12,269
    Quote Originally Posted by sfrawley View Post
    should be closer to 85
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    625
    It is usually a mm before the 90 degrees mark (it opens at 89C) at any speed so I guess yours is stuck open or might have been removed.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,868
    Mine operates between 85 and 95 - depending on traffic! It's got a new thermostat and radiator too!
    2005 Renault Clio 182 Cup
    8,431
    A sensible thing to do when having cooling system issues is to first check the calibration of the dash gauge and the thermostat opening temp non intrusively with an IR thermometer.
    You wouldn't be the first person to get conned into panic by a faulty dash gauge. Its good to eliminate those possibilities.
    Jo
    Feb 2001
    Goolwa SA
    339
    Thanks for all your replies. The gauge can indicate up to 90C in traffic which leads me to believe that the gauge is ok and the problem is more likely the thermostat.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Northern NSW
    1,079
    My guage tells me all sorts of things, most of which I don't believe. There are three sensors on the thermostat body and they are all a bunch of liars. One relates to the aircon, but I forget what the other two are directed towards. If my car ever overheats I'll just have to take it out in the paddock and burn the bloody thing.
    If I were you I wouldn't worry about it unless it tells you it's really hot. Then you undo a radiator hose and see if it's actually hot. When you find, like I did, that it's quite OK, you can put your saturday night back together and forget about the stupid guage and later fork out for yet another large bottle of coolant.
    These things are sent to try us, specially with these silly modern contraptions.
