Engine light of Doom!
Results 1 to 10 of 10
    PDJ
    PDJ is offline
    Fellow Frogger! PDJ's Avatar
    Central Coast NSW
    204
    Default Engine light of Doom!
    I took my S3 205 Gti out for a quick blast today.
    Just as I got back thinking "why don't I take me Pug out more often?" the engine light of discontent flicked on. So, I pulled up, jumped out and popped open the bonnet. Yep, the engine was still there so all good then. I was about to get the black tape out to put over the light when I noticed it was running like a 1960's American V8. Lumpier than a bag of lumpy things.
    I backed into the garage so I was in a good place to start investigation. I nearly didn't make it out! As well as being very lumpy at idle it is also pumping out copious amounts of black smoke. Black like a dirty diesel at full throttle. It smelled unbelievably rich. I can still see colours never seen before! I know I'm losing water as well somewhere i.e. an expansion tank every couple of drives. Hoping that is from a hole in a hose though.
    So, to sum up, Engine light on, lumpy tick over, rich smelling black smoke when idling, loosing water.
    The engine was rebuilt by the PO a couple of years ago. Any ideas on where to start or what the problemo might be would be appreciated.
    If its terminal I might be starting a which engine swap thread.
    Fellow Frogger! Roland's Avatar
    Perth
    727
    compression test should tells you lots
    PDJ
    PDJ is offline
    Central Coast NSW
    204
    Probably a good starting point. I'll go to Supercrap and pick one up tomorrow.
    9,261
    Quote Originally Posted by PDJ View Post
    Check to see if the air flow meter electrical connection plug has fallen out.
    This would cause running rich, don't know about the water loss though.
    Graham
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,440
    Default 205 diesel?
    Separate the the connector plug 1st along from the oxygen sensor the is screwed into the exhaust and check if it is clean inside, these accumulate water and "gunk". Yes you will have to jack up and get under the car to find the connector (sorry). If it is clean go to another plan.
    Good luck
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    If the K-Light is coming on - it will be throwing a fault code. Check diagnostics first, before pulling stuff apart!
    2005 Renault Clio 182 Cup
    7,483
    I agree with BIGRR. If the O2 sensor is broken, or has a bad connection due to corrosion in the plug etc., the car will not run very well at all. For some reason S3 GTi's rely heavily on the sensor.
    9,261
    So do the Sis, they run much better with a new O2 sensor.
    I still reckon check the AFM plug first, as the engine will run very rich if it is unplugged.
    Graham
    PDJ
    PDJ is offline
    Central Coast NSW
    204
    A few things for me to try there guys.
    Thanks for your help, I'll get crackin this arvo.
    Fellow Frogger! chez00's Avatar
    567
    water loss is still a concern and more than likely a separate issue. If it's a hose or something a thorough visual inspection of the engine bay will find some green blood. If not the coolant may be getting into the combustion chamber through a nasty crack or a blown gasket. have you noticed puffs of white smoke/steam out the exhaust particularly on start-up?
