505 Gearbox conversion
Results 1 to 9 of 9
    Member Oatsy's Avatar
    Apr 2011
    Lancefield Vicoria
    30
    Default 505 Gearbox conversion
    G-day
    I was planning on putting a gti manual gearbox into my auto sli, so any input on the conversion would be appreciated. (As in bellhousings flywheels and clutchs etc)
    Cheers Oatsy
    9,259
    Quote Originally Posted by Oatsy View Post
    G-day
    Cheers Oatsy
    You need a manual box from an SLI, SR or GR along with flywheel, clutch gearshift etc.
    The clutch is the only thing that will fit from a GTi.
    Graham
    Apr 2011
    Lancefield Vicoria
    30
    Thanks Graham,
    So that means that i cant use a GR bellhousing on the GTI box?
    Thanks, Oatsy
    9,259
    Thanks Graham,
    Thanks, Oatsy
    Pretty sure you can't, something to do with the teeth on the input shaft gears.
    Graham
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,103
    Graham
    That's right. More to do with the difference in the spigot end of the input shaft. The gti box has a short thick spigot, the xn has a longer thinner one. Meaning its not possible to just change bellhousings.
    Then if you swap the input shafts over to suit the engine, then you need to thoroughly check the meshing of the input shaft gears. I think the difference is mainly indicated if the shaft has a seal or a scroll.
    Matt
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    Fellow Frogger! James S's Avatar
    Aug 2002
    345
    Default SLi Manual
    Hi Oatsy,
    I sent you a PM. I am stripping a manual SLi.
    James
    Dec 2002
    Menzies Creek
    2,541
    Thanks Graham,
    Thanks, Oatsy
    If the GR bellhousing you have is for a BA10, then there is no simple way to do it.
    If you have one for a BA7 though, you can take the GTi input shaft to your local machine shop and have them extend the input shaft spigot by 10mm, and reduce the diameter from 17mm to 16mm, then reassemble the gearbox, fit the GR bell housing and it will all work. Clutches are the same between late XN engines and ZDJ engines.
    If you have access to a lathe and a welder, I can give you more specific information if you need it.
    Last edited by Demannu; 28th April 2011 at 06:59 AM. Reason: Too early in the morning. Not making sense.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by Demannu View Post
    If anyone has a spare BA10 bell housing, I NEED ONE - I have two boxes, both without bell-housings - dont ask why!
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Apr 2011
    Lancefield Vicoria
    30
    If it is so hard to change the gearbox how hard would it be to change the 2.2L gti engine and manual gearbox from the gti into the sli?
