rotor changeover obn 306
Results 1 to 13 of 13
    Lismore
    133
    Default rotor changeover obn 306
    Hi fellow puggers. I'm doing (was doing???) the rotor change over on my 306 this morning when I found that the Torx bit I was using (T 30 bit- correct size) was turning the torx bolt into licorice. So I stopped; wondering why they made such a small torx bolt when they could have gone for a hex or allen style head of a more substantial side?
    Anyone got any ideas?
    Keith
    Mar 2011
    19
    Penetrating oil and then try an impact driver to break the rust "lock". If the heads get too mangled, you may have drill out the heads and remove the screw remnants with locking pliers. Worst case may mean you end up drilling and retapping the holes
    Replace with countersunk Phillips head screws from an engineering supplier
    19,211
    Quote Originally Posted by leothepug View Post
    Keith
    First try would be soak overnight in an lube spray. Then tackle the bolt with a cold chisel, centre punch or similar. The idea is attack the the outside of the head tangentially with a hammer and punch/chisel and to try and rotate the bolt anticlockwise. Once the rust is broken vice grips will usually turn it. You could try some heat, I'm guessing it's been loctited. Heat breaks the locktite bond.
    Second try,if you have an arc weld or a mig welder, weld another hex head bolt on the (mangled) torx head. The heat helps to loosen the rust and then you can get some purchase of the bolt.
    I haven't seen the bolts so if you don't have good access forget the idea.
    Third try is grind the bolt head off with power file or angle grinder and after soaking attack the protruding bolt shank with vice grips or slip a nut over it and weld.
    It's rarely you get to number three method.
    I never put torx back. If it's corrosion prone replace with a stainless cap screw with a female hex head.
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,103
    Give Freeze n Release by Loctite a go. Bloody good stuff. I'd try it if the Penetrene didn't work, and before using the heavy duty solutions such as chisels etc. Once the hardware comes out, it's pretty much a one way street from there and can get messy quickly.
    Matt
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    12,266
    Quote Originally Posted by mlb View Post
    Matt
    true but it is fun
    another thing is to try striking the head of the bolt with a hammer, this is the first thing i do to break the tension/hold
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Lismore
    133
    thanx fellows for suggestions will try freeze and release, then hit with impact driver - I gotta buy one on wednesday when shops open again. Countersunk heads on bolts, will replace em with quality allan head bolt, hex wont fit, torx are stupid ideas. Such a small bolt for what it does. must've been designed with engineering theory and not common sense.
    Sep 2003
    North Parramatta
    3,997
    On the contrary, those particular screws only need nipping up - as they don't do anything once the wheel is bolted on - and most people when installing them either swing off them or use loctite (or a combination of the two).
    It's not nice for the next poor sole that has to undo them.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Lismore
    133
    Default torx bolts
    If they only need nipping up why then are they loctited so much that the correct tool rips the the head to shreds when tryn to undo them. Why arent they put in with threads lightly greased? Whatever the technical reason it appears that it hasn't been well workd out!!!!!!!!!!!!!!
    12,266
    you can't account for lard arsed mechanics that don't give a toss
    the only guarantee you ever have is to buy a car new and do it all yourself
    1 x 2018 3008
    8,426
    Bollocks.
    Torx are used to allow the (robot) tool arm to be positioned at a greater angle of line than other fasteners would allow.
    There was a time when i too didn't like torx fasteners and would strip the threads.
    I now love them as they are the friendliest faster for power drivers. In fact I'd go as far as saying the torx stay in better nick when driven fast and evenly as opposed to driven randomly crooked by hand with a ratchet handle.
    If you dont have quality torx bits, get some and never have these issues again.
    Follow all the advice given already, like using WD or penetrating fluid, giving it a whack to crack it, and you should avoid drama.
    There are torx screws and bolts on my car that have been removed 4 or 5 times, and still look like new.
    Jo
    Lismore
    133
    I can see Torx are easy and all that but a 4-6mm shank (well I guess it would be about that size lookn at the head of the bolt) appears not to be the size needed for the job (rotor to hub). i've got good torx bits! the head of the 1st bolt got slightly mangled. Getn Freeze'n'Releases from autobarn now
    Thanx for all hoo replied.
    An Australian, Kiwi, Englishman, Irishman, Yank, Canadian, German, French, Italian, Greek, Albanian, Hungarian, Russian, Pole, Czech, Slovakian, Spanish, Portuguese, Mexican, Argentinian, Brazilian, Japanese, Chinese, Indonesian walked into a bar and were refused entry; "Sorry mates, You can't come in here; You haven't gotta Thai"
    Sep 2003
    North Parramatta
    3,997
    Who knows?
    Let's face it - most people just love doing stuff up too tight. Taking it one step further and putting loctite on as well makes them feel even better
    Simon
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Default Torx arsed
    I've had this problem before... mine were pre-ruined by some over zealous mechanic.
    I drilled them out.. with a bit smaller than the thread size obviously. Once you cut through the head and it twists off, the threaded part of the bolt just works its' way further into the hole (from the force and vibration of the drilling) and out the other side!!!! Of course then I replaced them. I was lucky that one was removable before drilling, and I went to a bolt shop and bought a hand full of replacements to put straight in before I got the drill out.
    Seriously just drill the buggers out if you can't get them out otherwise...
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
