Urgent !!!! Location of paint code for Peugeot 306
Results 1 to 12 of 12
    Jan 2006
    128
    Default Urgent !!!! Location of paint code for Peugeot 306
    All, I'm getting a section of my car repainted after a small bingle, nothing serious.
    Anyway I just got a call from the smash repairers saying they can't find the colour code for the car. Its a 1995 N3 - 2 door - XR model.
    The code is supposed to be on the riveted metal plate next to the left hand suspension strut (when facing the car from the front). There is a reference but it indicates a Citroen paint colour when typed into their system.
    Can anyone hlep me with this ? The car is taped up ready to be sprayed and I was supposed to pick it up this arvo.
    The work is being done by MBI Smash Repairs in Marrickville.
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Not sure if the code position is different between N3 & N5, but mine is behind the passenger side (left) macpherson strut tower on the horizontal flange of the bulkhead/firewall & should be 4 letters long.
    It's possible the paint colour is shared between Cit & Pug.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Sydney, Australia
    308
    It won't be on a plate, it will be four letters like suggested, looks like it it written on with a white texter. Pugs & Cits do share colours too. Diablo Red is also Rouge Lucifer.
    What colour is it? Someone here will probably know from just that info.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    Apr 2011
    Mount Waverley
    91
    Citroens and Pugs do share paint codes....
    Paint code for my S16 is M0YC and it is also EYC and EYCC. You will find EYC in Citroen paint codes too....
    What's the paint code you are after? Try googling it....
    Member 96306N3's Avatar
    Sydney,Australia
    90
    I have an N3 and it is located in a green coloured texta right hand side of the engine bay in texta looking
    liked it has been sprayed / sort of airbrushed on. 93KG, escalate rouge . Scarlet red
    Member HOT306's Avatar
    103
    12,266
    Quote Originally Posted by boony View Post
    put a photo up of the car and someone will soon tell you what the colour and code is
    the smash repair should have a book at any rate telling them what cars in what years had what colours
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! matt_molon's Avatar
    Dec 2010
    SYDney
    192
    at my workshop citroen and peugeot share the same codes on the system we use also they should also be able to match ur colour with out the code it just might take an extra ten minutes, well at least we can at my work.
    2004 206 GTI 180 BLACK
    1998 406 2.0L auto ST WHITE
    [email][email protected][email]
    Jan 2006
    128
    Thanks for all your help. Apparently they found the paint but it hasn't resulted in an exact match. My car is a metallic silver and the colour used was plain silver.
    I remember when the car was ordered (new) my Mum requested the metallic silver, which was an optional extra. Does this mean the "metallic" colour is an after market option and not reflected in the paint code ?
    Apr 2011
    Mount Waverley
    91
    Do you have the paint code? If you have it you can try googling it and the guys from UK and an aussie site called peugeot logic has all the pug/cit paint codes and you can check whether if the metallic option is reflected in the paint code....
    but afaik the paint code should reflect the paint, and therefore all options like metallic or mica paints.
    306 S16
    Sydney,Australia
    90
    Dulux also do peugeot paints and can be made as requested by 3D Inspiration stores in sydney, Phil at the Campbelltown branch is a genius at paint match by sight also.
    Here is their codes.
    http://www.peugeotlogic.com/workshop...nt/paintc1.htm
    Auckland - New Zealand
    6
    I had a small incident with my 306xsi and had to get paint. On my 96 car the paint code was stamped on a plate in the boot on the back wall.
