XU9J4 Crank angle sensor
Results 1 to 3 of 3
    Jan 2011
    Traralgon
    648
    Default XU9J4 Crank angle sensor
    Here's something to remember.....
    Just replaced the crank angle sensor in a XU9J4 engine. The cross reference part number I came up with is CAS-065 but the part turned up in a Hyundai parts bag.
    If you are ever looking for a new crank angle for one of these, try your local Hyundai dealer first, their part number is 39180 22001. I would bet it's cheaper than the Peugeot comparable part. Their appearance is identical and it seems to work fine.
    Cheers.
    19
    i replaced mine about a year ago, as my power steering belt had worn a nice gouge in the side of it. its a bugger to put back and a bigger bugger when you lose the bolt between the engine mount and clutch body. (which i did, lucky i had access to a friends daughter with very small hands )
    Jan 2011
    Traralgon
    648
    Much easier on my car now, the power steering pump is gone - replaced with an electric power steering motor (not electric over hydraulic). The distributor is also gone, so the end of the bell housing is nice and accessable on my car now.
