206 gti 180 fluid levels
    Fellow Frogger! matt_molon's Avatar
    Dec 2010
    SYDney
    192
    Default 206 gti 180 fluid levels
    Hey guys can anyone advise me on a good increment to add engine oil to car as not too over fill. Also how can u tell where the coolant fill line is?
    Thanks for your help I'n advance guys.
    2004 206 GTI 180 BLACK
    1998 406 2.0L auto ST WHITE
    [email][email protected][email]
    48
    Should be in the owners handbook re. oil capacity. Are you topping up or refilling? As an indicator, from the min level on the dipstick, to the max, is probably around 0.5 litres.
    Coolant; should be a min and a max mark on the overflow bottle, this is the level when cold.
    brisbane
    102
    If its anything like my 180 you cant see the coolant level through the white plastic. One mechanic I know suggested using a bit of cloth to put down the reservoir so you know where the level is and go from there.
    Dec 2010
    SYDney
    192
    Ok thanks for the help guys yeah the white plastic on the coolant is annoying but u can't do damage have too much coolant any way though right
    268
    Oil capacity
    EW10J4
    With oil filter : 4.25 litres
    Without oil filter : 4.0 litres
    Level between MIN and MAX on dipstick : 1.7 litres
    EW10J4S
    With oil filter : 5.5 litres
    Without oil filter : 5.25 litres
    Level between MIN and MAX on dipstick : 1.5 litres
    Coolant capacity
    EW10J4
    Hot climates (45C) : 5.3 litres
    Temperate climates (37C) : 5.0 litres
    EW10J4S : 5.3 litres
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by matt_molon View Post
    It's in your owners manual under "Practical Information" and then "Checking Fluid Levels".
    At a more basic level, put in a little at a time, wait a minute, wipe the dipstick and check it. Practice until you get the hang of it.
    Coolant level on the 206 is very hard to see. You may find that using a torch or shaking the bottle (so you can see the fluid moving a bit) might help you see the coolant level. Don't feel you need to add coolant just because - it it's between min and max it should be fine.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
