406 rear end thump
    Sep 2004
    Marburg QLD/Wellington NSW
    173
    Default 406 rear end thump
    Have had a knock in the rear end of the 406. Asked the dealer to check all bushes in the rear suspension - told they could not find any explanation for the knock.
    Today I removed one of the rear wheels, and in doing so, found that , with the handbrake applied, the whole assembly could be moved back and forward by about 5 - stopping with a knock at the end of travel. It sounded to me just like the sound I am trying to trace.
    There is a nearly vertical lever rising from the brake assembly, linked via a bush to the suspension assembly.
    My expectation is that this bush is the source of the movement.
    Any comments?
    Member myshell's Avatar
    Dec 2010
    Tahmoor
    33
    Default rear end knock
    I think you will find you need to replace the rear suspension track arms. I had the same problem and new track arms solved it. They are also responsible for adjustinting the rear wheel alignment so get a 4 wheel alignment when you fit the new ones. see section 10.19 if you have the haynes manual.
    PUG 406 STDT
    Sep 2004
    173
    Thanks myshell- I have searched this elsewhere since your comment- I think you are correct.
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,865
    Quote Originally Posted by myshell View Post
    Yep - I fixed that, but the noises have come back! Considering there are numerous bushes - I think im going to bite the bullet and rebuilt the rear/front end of the car!
    Not bad, considering its an ex country car - 190,000km!
    2005 Renault Clio 182 Cup
