Engine codes for 505's
    1000+ Posts okalford's Avatar
    Sep 2004
    10,956
    Icon5 Engine codes for 505's
    I've had a good look around my car (and also did a bit of a search here) but can't find out what sort of engine my 505 has;
    ie as in the code.
    Someone was asking and they need it to source some parts.
    He asks for:
    Engine code (this identifies capacity/spec) – saying it will be something like ZDJ or ZDJL
    How can I work out which engine it is? It’s the original engine in an '88 build '89 GTi series 2 wagon. I have the engine no from the VicRoads (assuming the no is correct) could that help?
    There is some info on the bonnet that refers to an engine 'family' but the bonnet is not original and not necessarily from the same model 505. I do not remember seeing info like that on my original bonnet, I would have kept it if I had.
    Any clues most appreciated.
    '66 404 Wagon
    '78 504 Wagon
    '89 505 GTI S II Familiale
    Fellow Frogger! sideways_505's Avatar
    Perth W.A
    390
    It'l be a ZDJL mate.
    5,312
    Your engine number is under the inlet manifold, just near the starter motor.
    You'll need to be a bit of a contortionist to find it. I found it was easier to take a photo with my phone, but I've less room under my bonnet than most.
    Don't be wearing a short skirt when you go looking for it, or if you do, make sure there's nobody about with a camera.
    Mike.
    Started out with nothing, still got most of it left.
    Fellow Frogger! James S's Avatar
    Aug 2002
    345
    Default Engine Code
    Yeah, Sideways_505 is right. It will have a ZDJL engine in it. These are also called the Douvrin motor because of where they are made I believe. Yours will be a 2.2 litre.
