206GTI180 ABS removal query
    Fellow Frogger! Brett's Avatar
    Nov 2001
    617
    Default 206GTI180 ABS removal query
    Has anyone removed the ABS for track work on a 206gti180.
    I currently have an ABS fault on a track car and speedo is not working.
    The BMS has been told there is no ABS but the fault still comes up, even with ABS pump unplugged.
    The group N build manual shows removing the ABS unit, but doesn't indicate an electronic change.
    Any one have any experience on removing ABS?
    Thanks,
    Brett
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    Does it have a dedicated fuse?
    Maybe it could be as simple as that.
    Nov 2001
    617
    I'll check if there is a fuse, but it was disconnected from the cable.
    The BSI might also be an issue.
    It seems the ABS unit also controls the speedo.
    I'm fitting a Monit and that can give a speed reading any way, so I could just rip the lot out.
    It's only the stop light on the dash that will continue to stay on.
    Otherwise I fork out for an ABS pump unit
    Pics of some other progress below.
    IMG_0183 by Brettso, on Flickr
    IMG_0185 by Brettso, on Flickr
    IMG_0186 by Brettso, on Flickr
    Sep 2003
    North Parramatta
    3,997
    I can confirm that if you remove the fuse for the ABS, the speedo also stops working. They are definitely linked
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Nov 2001
    617
    Looks like abs system is coming out.
    Too expensive to replace.
    Vacuum booster going in to replace EBD/ESC unit and brake lines out of 206 xt with no ABS going in.
    Weighing up putting a bias valve in, but it would require revised brake lines, as there are individual pipes to each caliper.
    Anyone have experience of 17x7 wheels with a 24mm offset on a 206?
    Thanks,
    Brett
