Recommended Coolant
Results 1 to 8 of 8
    Mar 2011
    5
    Default Recommended Coolant
    Hello All!
    I've never joined a forum before so here goes.
    I have a 1995 306 sedan - was originally bought for my wife to run around in but we started having a few problems over the 3 years that we have owned it so now it's mine.
    I have just replaced the headgasket and I need to be sure that I am using the right coolant. I have been told the normal Glycol antifreeze is no good.
    Any advice?
    Regards
    Clive
    268
    Welcome to AF!
    A year ago, I went to Peugeot to purchase some coolant, and got the 2 litre bottle (9735 K1) for $20. Doesn't seem that much more expensive compared to non-OEM brands.
    Here are the part numbers for long life coolant (pre-diluted):
    2 litres: 9735 K1
    5 litres: 9735 K0
    20 litres: 9735 J9
    210 litres: 9735 J8
    Mar 2011
    5
    Thanks, I'll give it a go.
    Oct 2005
    Rome
    2,660
    And Clive...
    Welcome to
    Hopefully we will hear more about your Gaulic motoring experiences
    Dave
    ​1997 BMW K1200RS
    IR655
    Fellow Frogger! Binky's Avatar
    15 Credibility st. Nth Fitzroy, Vic.
    227
    Welcome Clive!
    Glycol is corrosive, but is good as an antifreeze agent. Non-glycol radiator fluid is much kinder to your cooling system. However non-glycol isn't really antifreeze, so if you're planning a trip to the snow, by all means put a glycol antifreeze in your system, but be sure to flush it out and replace with non-glycol when you return to standard Australian plus zero temperatures.
    Binky.
    268
    Also, the OEM long life coolant will provide protection down to -35C which should be plenty for trips down to the snow.
    Mar 2011
    5
    Thanks for the advice and the welcomes.
    The old gasket was rotten when I got it out. I undid the headbolts and just lifted the head off!
    Clive
    Mar 2011
    Kendenup WA
    124
    Some months ago I did some research on this.
    One of the serious problems with most proprietary coolants is that they contain amounts of silicon and silicon is a no no for oxygen sensors and catalytic converters.
    Another problem, and I suspect why Binky mentions corrosion, is that after a year of use a coolant starts becoming an electrolyte which allows a transfer between the anode and cathode of different metals such as ferrous and non-ferrous metals -- i.e. aluminium etc.
    Experience has found that refilling with distilled water and adding an inhibitor gives all the protection needed.
    During my twenty years of previously living in Perth the very mild frosts occasionally experienced never caused any problems.
