406 HDI mid range torque
Results 1 to 11 of 11
    Sep 2004
    Marburg QLD/Wellington NSW
    173
    Default 406 HDI mid range torque
    I got the 406 HDI back from its initial (for me) service, and find that it still seems to be down on mid-range torque compared to the 405 SRDT. Where the 405 seemed to have a good steady surge from around 1750 RPM, the 406 seems to be 'OK', but only has a massive surge around 3000RPM.
    I expect that I can get used to it, but it certainly not as I would expect after the 405.
    Anyone able to say whether this is normal for the HDI?
    Fellow Frogger! jurgen_s's Avatar
    Belgium
    707
    no not normal:
    http://en.wikipedia.org/wiki/Peugeot_406
    look at the engine table and you will see this:
    2.0 HDi DW10 ATED 4 / 8 1.997 cc 109 PS (80 kW; 108 hp) / 4.000 250 Nm (180 lbft) / 1.750
    This means that you should also feel the kick in at 1750 rpm and not at 3000 rpm.
    www.peugeotforum.be
    Belgium Peugeot Club
    Sep 2004
    173
    Thanks Jurgen - as I expected, this is not normal. Is there any adjustment of the Turbo, or might this mean replacement is the only solution? anyone have information on this?
    Belgium
    707
    the (st)dealer is the way to go. It can be several things that might be worth checking. Air-ratio measurement, overboost valve, etc.
    Get it hooked on the diagnostic computer and see what shows up.
    www.peugeotforum.be
    Mar 2011
    413
    This may or may not help! A little while back my housemate's Z30 Soarer with the 1JZ-GTE was having similar issues, which ended up being a broken seal in the turbo piping. The turbos spooled fine so he didn't know what was wrong until he replaced the "broken" boost meter (which was reporting almost no boost) and the new one gave similar results.
    12,269
    could also be a hose that has come adrift
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Sep 2004
    173
    Thanks again I will look at all of these -
    Sep 2004
    173
    Since I have been driving the car for a few days now, I have discovered that, if I DO get the turbo engaged in lower gears, it keeps on as I change up through the gears( naturally it is still spinning).
    The difference is very obvious, so : The motor should have much more power than it has been delivering.
    Sep 2004
    173
    HAd a bit more driving experience now, and have discovered that the turbo cuts in early on a light throttle, but not if you plant the foot. It's a weird experience, because you have to back off in 2nd or 3rd gear to get the turbo to operate.
    When it does, the car behaves as I expected, and performance stays right through the remaining gears.
    Any clues, or is this just 'turbo lag' which I have not experienced in 4/405srdt that I have driven over around 200k?
    At least I now know how to get it driving 'normally', and it is a great car.
    651
    Quote Originally Posted by marburg505 View Post
    Some sort of overboost issue? Sounds like the electrickery might be cutting fuel when you're getting full boost.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    London, UK
    294
    the control solenoid might be worn out
    I beleive that the EGR control solenoid and the boost control solenoid are the same, therefore you can swap them to see if it improves things
    make sure that you mark the vacuum hoses because the hoses have to go on the solenoid the right way around
    the solenoids are cheap if you want to buy a new one
