Hi guys,
Big G'day
I've been having fuel economy issues in my 79 504 gl, basically it absolutely chews through the fuel where I'm getting a couple of hundred k's out of a tank
. Before I take it somewhere I thought I'd run it past you guys to see if there is anything I could rule out in the limited scope of this thread.
Car starts fine, runs smooth, accelerates fairly well, uses 98 octane fuel.
Smells a bit petroley after I pull into driveway and turn it off.
I checked and it has a solex carby, but i have no idea what type etc! The car doesn't stutter, or misfire etc, and it doesn't seem to leak any fuel when parked for extended periods of time.
Has anyone had similar problems and had any obvious remedies/checks that one can do to rule anything out?
Thanks heaps frogs,
Jock
