Rear Window Seal
    Jan 2002
    1
    Rear Window Seal
    I have finally tracked a water leak in my 205 GTi to the rear window seal, after sealing the rear hatch lock with silicone. I was wondering if anyone else has replaced the rear window seal, who would be best to do this and an approximate cost for the repair.
    Thanx in advance
    Walrus (because I seem to be deep in water)
    south australia
    225
    try windscreens obrien or you local glass specialist,cost may be around 70.00.depends if seal can be reused.
    Local Tyrant gibgib's Avatar
    Mar 2000
    Sunshine Coast, Queensland
    3,515
    Walrus,
    You might want to apply some fish oil before the seal goes back in too.
    Mine had the makings of a rust bubble in the paint just where the join in the seal is.
    490
    ...and make sure you use silicon with a neutral cure, otherwise it gets very acidic and takes paint off, causes rust etc.
