Fuel pipez for a 306 S16
    Member Clippit's Avatar
    Hobart
    53
    Default Fuel pipez for a 306 S16
    Hello,
    So you know those Peugeots right? I want to replace the last run of the fuel hoses in mine (to the fuel rail) as they're a bit old and short. I went to the local hose place (wow would you look at all those hoses) but they didn't have anything big enough. I've measured the metal pipez on the fuel rail - delivery inside diameter is about 8.5mm, return 6mm, so I guess I need something at least that big for each.
    Where do you get your fuel line? Should I go silicone? Also, what's the correct routing (I'm sure mine's wrong)?
    Also also, vacuum tube? Alternatives to standard hard-when-cold stuff? Silicone?
    Cheers guys
    Perth
    60
    EFI hose from ENZED
    Jan 2011
    Canberra/Sydney
    166
    Hey Clippit,
    Check out these guys: seems like the stuff they sell is top quality.
    http://www.eaton.com/EatonCom/Market...lics/index.htm
    The prices are in feet not meters.
    What you got against Hobart!?
    Hobart
    53
    Quote Originally Posted by owendaniel View Post
    Hey Clippit,
    Thanks guys, i'll investigate both of those. Now have a long list of minor things to fix
    I have nothing in particular against Hobart, I just don't live in it.
    Member HOT306's Avatar
    103
    G'day. One of my EFI rubber hoses going to the fuel rail has started a slow leak coming from the join. The hose is stamped 1994 lol. Quite a concern, so staying in the garage?
    How far down do the hoses go down? Do I need to take the right front wheel off to access? Any help would be good.
    Hobart
    53
    If it's an S16, I don't think so. Should be able to just reach up behind the subframe and find the join.
