Just my luck
Results 1 to 8 of 8
Thread: Just my luck
    12,269
    Default Just my luck
    today i thought i would get out and finish ripping the engine apart in the 604 and put new head gaskets in
    the plan and beer were going well untill i got the first head off and although i did everything the way one is supposed to do it the rear liner on the drivers side was "floppy"
    damn it the engine has to come out so i can redo the liner seals
    grab the 3rd beer and start on the other head just to make the job of getting the engine out easier and of course getting the head off in the car is a much easier job (can never work out why people always say it's a hard job with 604's and head gaskets)
    anyway as i do valve clearance checks every so often and i check everything while i have the rocker covers off there were two loose head bolts
    now this through me as the blown gasket was on the drivers side but doing one head i may as well do both just in case and lucky i did
    now the heads were only checked less then 2k km's ago
    on the plus side the engine internally is blooody clean
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,957
    Maybe, the head gasket failed because a liner had settled? Been there with Volvo's. Hopefully, your block is not corroded - been there with Volvo's too! Hopefully these worries had been completely overcome by the time they got to XM engines! (Thinking about it, how ever did I get into another PRV-engined car anyway!) At least you now get to set the liner protrusion properly!
    I don't know if the Pug is the same, but Volvo changed the timing cover sometime in the late 1970's by changing the length of a lug on the casting down near the crank. Idiot here managed to snap a cover when I overlooked this and it tried to fit an early cover to a later 2.7 engine. Or was it vice versa? It is mentioned in the Haynes 260 manual anyway, so I should have known better.
    12,269
    nah
    gasket failed due to then engine becoming a tad too warm more than once
    the engine only has 30k on it
    your cover must have been from an early volvo to have that problem, all 604 engines were the modified type
    1 x 2018 3008
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,444
    Default Sign of old age!
    Quote Originally Posted by pugrambo View Post
    the plan and beer were going well until i got the first head off and although i did everything the way one is supposed to do it the rear liner on the drivers side was "floppy"
    on the plus side the engine internally is bloody clean
    I assume it was you that removed and replaced the heads last time as well, how old are you now !
    604s heads appear to come off and go back on frequently, do some of the parts go back on by themselves ?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    12,269
    Quote Originally Posted by BIGRR View Post
    i use wing nuts on them
    easier and quicker
    1 x 2018 3008
    CitroŽn Tragic UFO's Avatar
    9,740
    Jeez mate, sounds like you needed some expert help! XM Mechanic, XM Driver, SLC 206 and I were all waiting on the call, but you wallowed in!
    12,269
    well engine is out and the two holes on further inspection from where the loose head bolts came from have pulled threads
    now i got this block modified and asked to have everything checked while the machinist had it to make sure all was good
    now even though i did overheat the poor girl a couple of times i do tend to think that the reason for the head gasket blowing was the dodgy threads on the one head loosing tension
    damn shame it was too long ago to claim a warranty even though the engine has only done 30K
    now i do have another block i can use but i might even just get this one heli coiled seeing as i have to pull the damn thing apart anyway
    all this added work i really didn't need to do and pisses me off now i know it wasn't my fault
    1 x 2018 3008
    Dec 2002
    Menzies Creek
    2,541
    I think all aluminium engines should have helicoiled head bolt threads. There's a certain 11:1 compression douvrin 4 cylinder in my garage that has all 10 threads helicoiled. Don't want that head moving. The V6 turbo will be the same, but 16 helicoils costs more!
    Scotty
    Melbourne - Dandenong Ranges
    1999 Peugeot 406 Coupť - 'Chloe' - 5 speed manual
    2014 Peugeot RCZ - 'Remy'
