306 s16...
Results 1 to 12 of 12
Thread: 306 s16...
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    Default 306 s16...
    I recently acquired a 306 S16 and unfortunately it has developed an unforeseen issue.
    When starting the vehicle and driving for 20 minutes, it runs perfectly fine, after pulling over for 5 minutes or so and restarting the car, it will start running on 3 cylinders. The next day, it will run fine again for the same period of time, 20 minutes or so, until pulling over.
    Does anyone have any clues? Would it be coil problems?
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    Dec 2010
    54
    when driving in the 'first 20mins', is the car running on all 4 cylinders at all throttle ranges?
    May 2004
    1,057
    Quote Originally Posted by aj1221 View Post
    Definitely yes.
    Expert 2.0L (2009)
    Dec 2010
    54
    my guess would be to determine the cylinder which isnt firing (i think there was a thread on this recently) and have a look over leads, coils etc to see if anything looks faulty. next step would be to replace them... although im not sure why it would be fine for the first 20mins and then on 3 cyclinders next start up
    Perth
    60
    It will be one of your coils. Faulty ones tend to play up when they get hot.
    Fellow Frogger! AndS16's Avatar
    Dec 2010
    Newcastle
    158
    Sounds just like a coil problem.
    I have a brand new valeo here,$60 plus postage
    if you want,or get one off the sponsers here on AF.
    Dapco Imports are who I deal with. In Sydney.
    Send a pm if you want this coil.
    Andrew
    Member eatpeople04's Avatar
    Apr 2005
    Eltham, Victoria
    116
    I would agree, sounds like a coil pack, better get on it soon or else it will fail completely.
    I had to change one on my GTi6 recently (thread) and it is easy to find out which one it is. Just remove the cover plate and 1 coil pack and plug at a time, when you fine the fouled one replace that coil pack!
    (obviously this won't work if you car is still running on 4 cylinders just before checking)
    Good Luck!
    (Conversly you could wait until the problem appears, stop the car and unplug a coil pack at a time, start it in between each and see which one doesn't make it worse, but I'm not sure if this could possible cause any damage)
    eatpeople04
    Now showing in:
    "Betty" 1997 Black 306 GTi6
    "Shaggy" 2001 Green Subaru Outback
    The Mrs. Has
    "Wags" 2006 Ash Grey 307 XSE Hdi Touring
    And for floating...
    "Korka" 1978 Red/Blue Ramsay Lynx with 327ci Chevy
    Previously:
    "Cliff the 505th" 1985 White 505 GTi
    "Clive the 505" 1983 Poo Gold? 505 STi RIP
    1000+ Posts dino's Avatar
    Nov 2002
    4,606
    Quote Originally Posted by Uga Boga View Post
    Car doesnt like you...end of story.
    Think of it as a wife who constantly has a "headache" when you want "some"...Trust me...get another car, this one isnt for you (said using "generic" Jedi Knight voice)....
    dino
    Fellow Frogger! patpug's Avatar
    614
    I've had this problem on other cars before and it invariably turns out to be one of the high tension leads. maybe try replacing them before doing the coil?
    205 gti-6
    205 track car build in progress http://www.aussiefrogs.com/forum/res...-race-car.html
    Member HOT306's Avatar
    103
    Sounds like a coil pack. The S16 requires a lot of attention and TLC. Unforeseen issues are a part of these vehicles.
    However, having said that, they are a joy to drive. It depends how much you love her.
    Fellow Frogger! Davo81's Avatar
    Mar 2011
    Kyneton, Victoria
    180
    Quote Originally Posted by HOT306 View Post
    please don't say that!
    Dec 2010
    232
    Just a coil pack, $90 from EAI, or see above !
    Takes 5 min to replace
