306 S16 oil leaks help
    Jan 2011
    Wyndham Vale
    17
    Default 306 S16 oil leaks help
    Hi all, im new to the forum and new to Peugeots.
    Bought my first Pug, a 1996 306 S16, a few months back and have been slowly fixing it for an RWC
    Now its got a few oil leaks, ive replaced the rocker cover Gasket and attempting to do the sump cover gasket.
    can some one please advise me on how you change the sump gasket??
    Had a weak attempt at it today and gave up trying to remove the A/C pump (started getting too hot and frustrated, thought i best stop before i break something!!)
    Also i have oil drips on the diff housing part of the Gearbox and im unsure where it could be coming from. Is there a common place around there that could leak oil??
    Any Advice would be much appreciated
    Thanks, Josh
    Member HOT306's Avatar
    103
    1996 S16? I thought the S16 was 1994/1995?
    Jan 2011
    Wyndham Vale
    17
    Its got a Late 95 build plate and first regoed in 96
    Dec 2010
    232
    Oil on the diff housing would be coming from the drive shaft oil seals in the gearbox.
    I once thought I had a leaking sump, turned out it was the crank shaft oil seal on the timing belt side leaking and dribbling down and aroud the oil sump instant gasket. Worth a look just in case i guess.
    Jan 2011
    Wyndham Vale
    17
    Thanks for that Blink. ill check it out on the weekend
